4 LO Light Flashing and beeping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Sep 27, 2010.
  1. Sep 27, 2010 at 6:50 AM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    Is this normal?
  2. Sep 27, 2010 at 6:52 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    It's not engaged if it beeps and flashes
  3. Sep 27, 2010 at 6:54 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    If it's beeping 4 low has not engaged yet. Try putting it in reverse and moving just a little, then back into drive. It should engage. Takes a while sometimes if you haven't used 4 lo in a while.
  4. Sep 27, 2010 at 6:54 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yup...That should be on solid with no alarm/beeping noises if you are in 4Lo.
  5. Sep 27, 2010 at 6:55 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Correct. I means that you are either in gear or moving while trying to engage 4lo. It is telling you that the conditions aren't right to get into that mode.
  6. Sep 27, 2010 at 7:02 AM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Thanks guys
  7. Sep 27, 2010 at 7:51 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Stop the truck.
    The tranny needs to be in NEUTRAL (not PARK) when you rotate the dial from H4 to L4.
    That's it!
    Push the A-TRAC button down by the cigarette lighter once (if your TRD is an Off Road) and you will automatically have Active Traction Control each time you go into L4... Gives you front and rear locker action.
