4 LO Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10ptXtreme, Jan 28, 2015.
  1. Jan 28, 2015 at 6:01 AM
    10ptXtreme
    10ptXtreme [OP] Well-Known Member
    NJ
    2020 DCSB TRD Sport Voodoo Blue
    With the recent storm, I went out to play with my fairly new DSCB. For the first time I put the truck in 4 LO and needless to say I was shocked. In first gear, I didn't see any difference in rpms between 4 LO and 4 HI. I will admit that I didn't go thru a bunch of gears but from 0-10mph, the rpms went up to 2k with both HI and LO.
    For reference sake, I remember with my old 95 Toyota Pickup 4 LO was much, much lower geared. Is this normal or what?
    David
  2. Jan 28, 2015 at 6:04 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Are you sure 4 LO engaged? If you heard beeping it wasn't engaged. Make sure you come to a COMPLETE stop, push the clutch the entire way down and then turn the knob to 4 LO. You will hit 2k rpm a lot faster!
  3. Jan 28, 2015 at 6:07 AM
    10ptXtreme
    NJ
    Yeah it was beeping. But it was beeping for a bit of time like 15 seconds. How long do I need to wait for it to engage?
    David
  4. Jan 28, 2015 at 6:13 AM
    Cohutta
    Cohutta Well-Known Member
    Georgia
    2011 4x4 AC 2.7
    Dog hair
    If it doesn't engage, scoot forward or backwards a few feet, come to a complete stop in neutral and try again.
    Also, as stated, make sure the clutch is completely depressed.
  5. Jan 28, 2015 at 6:13 AM
    Cohutta
    Georgia
    2011 4x4 AC 2.7
    Dog hair
    If it's beeping and no light on your dash, it's not engaged. Simple as that.
  6. Jan 28, 2015 at 6:19 AM
    NC15TRD
    Nick
    PA
    Should work immediately but if not:
    ^this
  7. Jan 28, 2015 at 6:27 AM
    10ptXtreme
    NJ
    Ok thanks guys... I'll try it again later when I leave from work.
    David
  8. Jan 28, 2015 at 6:29 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    On the side note why do you need 4Lo in the sno ? (it reven rhymes) :D
    99.9% of the time you run 4HI in the snow. 4low is more for rocks, logs when you need massive amount of steady torque.
  9. Jan 28, 2015 at 6:31 AM
    10ptXtreme
    NJ
    I didn't need it; I was just playing around with it.
    David
  10. Jan 28, 2015 at 6:38 AM
    BlueT
    NorthEast
    Good stuff, play is fun. :D
    I was just curious.
  11. Jan 28, 2015 at 7:45 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Agree with what everyone is saying. You definitely weren't in 4 low. You would know for sure. Long Island got some decent snow, was able to take the truck out before most of the roads were paved. It was fun, traction is great in 4hi.
  12. Jan 28, 2015 at 8:12 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I try to use 4hi for a little while every month to keep everything working (use it or lose it). I've only messed with 4lo three or four times. Will shifting to 4hi lube up the same parts as shifting to 4lo? Or do I need to use both on a regular basis?
    I have the locker too and realize I need to be in 4lo to give that a nice workout so my point is probably moot, just curious.
  13. Jan 28, 2015 at 8:15 AM
    The109
    Fort Collins
    Thanks Rock Lobster!
  14. Jan 28, 2015 at 9:02 AM
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    The same way you go into 4lo. I put my truck into 4lo then push the locker button until it blinks and put it in drive and it engaged. I hadn't used mine since the first winter I bought it back in '13/14.
  15. Jan 28, 2015 at 12:54 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Sometimes it does engage that easy... other times you need to turn the steering wheel full right (or left), then roll forward until it locks.
    As troublesome as it can be to use, it is nice that the locker is only an emergency back up (since 2009), as A-TRAC turns on and works with such ease. There are a couple of instances when using both A-TRAC and the locker together can be advantages, but typically all Low Range driving with the A-TRAC in the on mode will be all you need to get anywhere!
  16. Jan 28, 2015 at 2:46 PM
    10ptXtreme
    NJ
    Ok... So I tried doing it again and had no issues. It worked perfectly. I must not have depressed the clutch in; my 95 didn't need to.
    David
  17. Feb 1, 2015 at 4:40 AM
    coveylane
    coveylane Well-Known Member
    Coveylane
    Nova Scotia
    08 Tacoma SR5 4x4
    I have a plow on mine and I use 4Lo but I was having trouble getting mine in yesterday. This thread helped that. (too bad it was after I plowed. The snow and slush was very heavy) I thought there was a problem with the truck but it was just me. After reading all this, I tried it and it went right into 4Lo.
  18. Feb 1, 2015 at 4:16 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    This is my third toyota 4x4 pick up
    At the 1st of the month, engage both the hi and low 4WD for a couple miles
    usually in a straight line not to bind anything up
    But I have never had a drive train issue ever.
