4-lo won't engage (solved)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zach O, Nov 18, 2017.
  1. Nov 18, 2017 at 3:36 PM
    Zach O
    Zach O [OP] Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    Today I decided to try to engage 4-lo to make sure it still works since I have barely ever used it since buying my truck. I have been engaging 4-hi a couple times a month to keep everything working but have neglected 4-lo and the locker since I have very few opportunities to use them lately. Even so, I feel that there shouldn't be any problems this soon. I know to keep the clutch depressed and the speed below 2 mph but I tried like 15 times with no success. Is it likely that the ADD actuator is bad already? Or is there something I'm overlooking?
  2. Nov 18, 2017 at 4:25 PM
    badger
    badger Well-Known Member
    07 SR5
    perfectly normal ;)
  3. Nov 18, 2017 at 4:29 PM
    badger
    07 SR5
    Only half kidding. These trucks can be finnicky going into 4 lo. I would try going in reverse just a couple of feet and try again. I would be stopped when you try, but you may need to move the truck a bit back and forth to get engagement. This is why I did an FJ twin stick swap.
    old55guy likes this.
  4. Nov 18, 2017 at 4:29 PM
    Zach O
    Zach
    Texas
    Haha. I just figured it out. My floor mats were making the clutch not depress all the way. I forgot that since putting them in I have been having to push it harder to start the truck. I didn't realize that I had to do the same for 4-lo.
  5. Nov 18, 2017 at 4:31 PM
    Pigpen
    Dan
    Northwest Montana
    Make sure you're at a complete stop. It will not engage if rolling. As the parts break in, it will go in easier. Mine was a pain in the dick to engage for the first 50,000 miles or so. It lead to me Pliny the clutch in 4 high numerous times. Now, at 95K+ miles, the t case shifts pretty reliably. It often helps to make sure you're pressing the brake pedal firmly, and the clutch needs to be pressed to the floor. Again, completely stopped only.
  6. Nov 18, 2017 at 4:31 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    1st is the 4wd light (green light on dash with lil lines connecting all 4 tires) fully illuminated and not flashing when you are in 4HI?
    FYI you CAN NOT go directly from 2wd to 4lo. You must get fully into 4hi first. Once you are fully in 4hi (easiest to do so while moving, you can technically engage at up to 60mph, only do so on low traction surfaces or in a straight line on pavement). Then come to a FULL stop, Push that clutch ALL THE GOD DAMN WAY TO THE FLOOR, not just in, im talking mashed to the floor. Then flip to 4lo. It might take a lil moving forward / slipping of the clutch to get it to go all the way in but it will go in. If everything is in and lights all solid on the dash, you are in 4lo.
  7. Nov 18, 2017 at 4:32 PM
    Pigpen
    Dan
    Northwest Montana
    We were typing at the same time
  8. Nov 18, 2017 at 4:33 PM
    Pigpen
    Dan
    Northwest Montana
    My 4 lo light blinks (yellow wire mod)
  9. Nov 18, 2017 at 4:33 PM
    Zach O
    Zach
    Texas
    Yeah I just went out to try it once I realized the error in my ways. Lol.
  10. Nov 18, 2017 at 4:36 PM
    nd4spdbh
    SoCal
    Feels good to have atrac. :p
    Pigpen[QUOTED] likes this.
  11. Nov 18, 2017 at 4:59 PM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Yeah, I had the same problem w/ my last Tacoma and then I finally figured it out. You literally have to push the clutch ALL THE WAY, lol. After I learned that, no more problems putting it into 4Lo. My new Tacoma is also a Manual and now I know lol
  12. Nov 18, 2017 at 5:16 PM
    Zach O
    Zach
    Texas
    Yeah the clutch pedal contacts my husky liners slightly so I just have to push it a little harder. I'm glad that's all it was.
    Scooter WCT[QUOTED] likes this.
  13. Nov 18, 2017 at 6:06 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had this same problem several months back. I was baffled until I came back inside and did a little web surfing.
  14. Nov 18, 2017 at 6:23 PM
    Pigpen
    Dan
    Northwest Montana
    the switch that the clutch has to hit to make this happen should be adjustable. You should be able to dial it out a hair to make engagement easier.
  15. Nov 18, 2017 at 7:35 PM
    Zach O
    Zach
    Texas
    I might have to take a look at it tomorrow. Is it pretty easy to adjust?
  16. Nov 18, 2017 at 9:16 PM
    Pigpen
    Dan
    Northwest Montana
    I've never done it. There's a thread somewhere about people having difficulty starting their man trans trucks due to similar issues. They figured out how to adjust this and it solved the issue.
