4 LOW ALARM DISABLE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirtrider262, Apr 23, 2013.
  1. Apr 23, 2013 at 7:30 PM
    dirtrider262
    dirtrider262 [OP] Member
    southern oregon
    2013 MGM TRD OR DCSB 4.0 6SPEED
    damn that thing is annoying can someone point me in right direction as to turn that thing off
  2. Apr 23, 2013 at 8:57 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Follow the proper procedure for engaging 4 low? Problem solved :notsure:
    #thereforareason
  3. Apr 23, 2013 at 9:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  4. Apr 23, 2013 at 9:22 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I believe it goes from 4Hi then to N then to 4Lo. bye bye beep beep.
  5. Apr 23, 2013 at 9:24 PM
    OZ-T
    Peter North
    British Columbia
    There's a card on the visor , driver's side
  6. Apr 23, 2013 at 9:29 PM
    jmg256
    Al Tonter
    TRD Offroad
    This, or rtfm
  7. Apr 23, 2013 at 9:31 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    :facepalm:
    Stick it in neutral so you can actually engage 4lo.
    Oh youre a manual. I believe its a different set of steps for you. Check the manual mate!
  8. Apr 23, 2013 at 9:31 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    From what i've read the clutch pedal needs to be buried to the floor for 4L to engage with the manual's. The beeping noise is telling you your not doing it right.
  9. Apr 24, 2013 at 5:56 AM
    dirtrider262
    southern oregon
    damn this site is good will read manual as advised
