4 Low Alarm!!!
Discussion in 'Off-Roading & Trails' started by seabeau, Sep 14, 2013.
  1. Sep 14, 2013 at 12:34 AM
    seabeau
    seabeau [OP] Active Member
    Ga.
    Tacoma 4X4
    Beeping alarm, while in 4 low during Tacoma test drive! Is this normal? How long does it last? Can it be stopped? I'm brand new to late model
    Toyota 4X4s! Thanks!
  2. Sep 14, 2013 at 12:39 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Beeping means you did it wrong...
    Must be in N and traveling less then 5mph to engage into 4L
    But you can shift on the fly into 4H at any speed up to 65mph
  3. Sep 14, 2013 at 12:49 AM
    seabeau
    Ga.
    Tacoma 4X4
    Truck was an automatic. I had stopped,put trans. into neutral,turned/pushed knob into 4L. Thats when the dang beeping started! Thanks!
  4. Sep 14, 2013 at 3:49 AM
    Joe D
    Joe D .
    Yea but, just because the switch is in a position doesn't mean the low 4 is engaged. That was your issue. You had a disagree between the switch postion and the actual drive train configuration.
    us3rnam3 likes this.
  5. Sep 14, 2013 at 4:07 PM
    seabeau
    Ga.
    Tacoma 4X4
    How is the issue resolved sir?
  6. Sep 14, 2013 at 4:11 PM
    MonkeyProof
    SoCal- SGV
    Resolve the human error and the issue will correct itself lmao
  7. Sep 14, 2013 at 4:19 PM
    pilotace001
    pilotace001 Member
    Georgia
    Double Taco aka "DT"
    All-Weather heated seats, Tonneau tri-fold
    Just had that issue when I took the truck on a little offroad. Turn on, off a few times. For me it worked when I actually put the truck in gear and started rolling at about 1mph... then it locked in (same prob when trying to disengage) eventually it locks / unlocks. But mine is manual trans - so may be a little different.
  8. Sep 14, 2013 at 6:13 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If you follow the instructions exactly as they appear on the sun visor, it will work. You should already be in H4... since L4 if for more extreme hill climbing, mud crossing etc. I suggest going into H4 as soon as you are off the pavement (you are suggested to use 4WD once a month for 10 miles by Toyota anyway). When you come to a place you need maximum power or crawling ability... if automatic: stop and put automatic tranny into N Neutral (not P Park)... rotate and depress dial into L4... put tranny into D Drive or a lower gear... (2009+ Off Road I also recommend pressing the A-TRAC button to have max. traction and no traction loss to slipping tires).
    9mmMike likes this.
  9. Sep 14, 2013 at 8:36 PM
    spicytaco831
    spicytaco831 Active Member
    Max
    Monterey (CenCal)
    06 4x4 storm trooper
    Sometimes my truck gets stuck in 4lo or4Hi depending if I'm on a hill. All I have to do is reverse and it usually releases the pressure on the axel and it disengages... And the annoying beeping stops.
  10. Sep 15, 2013 at 10:10 AM
    David K
    Leave it in 4WD until you are ready to get off the dirt. As for getting out of low range... in all three of my Tacomas, the only issue was if I forget to put the tranny in neutral (N) before turning the dial/ pulling the shifter out of L4. Beeping should only be going on if you forget to be in NEUTRAL.
  11. Sep 18, 2013 at 1:22 AM
    seabeau
    Ga.
    Tacoma 4X4
    David: Thanks for the info,I'll give these ideas a try next time out!
  12. Jul 28, 2017 at 9:33 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    I miss my shifter t-case..
