4-low beeping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TRD Sport, Jan 31, 2010.
  1. Jan 31, 2010 at 9:14 AM
    08TRD Sport
    08TRD Sport [OP] ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    Hey guys I finally used my 4-low today and when I put it in 4-low it beeps is that normal. my 4-high it doesnt but as soon as soon as I put it in 4 low it flashes 4-low and then starts to beep
  2. Jan 31, 2010 at 9:17 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    You need to come to a full stop, put it in Neutral (Auto Trans?), and then rotate the dial from H4 to L4. The beeping means it isn't engaged. Youe WILL feel the difference in L4... tons of low end torque!
  3. Jan 31, 2010 at 9:19 AM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    you might have to move the switch back and forth from 4hi to 4lo a few times to make it engage.
  4. Jan 31, 2010 at 9:23 AM
    David K
    Did you read the owner's manual or that card in your sun visor (that explains exactly how to use 4WD)?
  5. Jan 31, 2010 at 9:30 AM
    08TRD Sport
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    yeah I have come to a complete stop put in in park then went to 4-low and put it in L on the trans and it flashes and beeps. I did not try to move it back in forth a few times but I will try it today when I got back out
  6. Jan 31, 2010 at 9:31 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Go to a complete stop and put it in neutral then engage 4L
  7. Jan 31, 2010 at 9:32 AM
    braggman7
    braggman7 Well-Known Member
    Athens, GA
    '10 Double Cab TRD Sport 4WD
    put it in neutral. not park.
  8. Jan 31, 2010 at 9:34 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2
  9. Jan 31, 2010 at 9:37 AM
    David K
    NEUTRAL... not park! (oh yah, x3)
  10. Jan 31, 2010 at 9:42 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    oh yeee x4
  11. Jan 31, 2010 at 9:54 AM
    08TRD Sport
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    OK thanks let me go try it
  12. Jan 31, 2010 at 9:56 AM
    08TRD Sport
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
    it works .... thanks
  13. Jan 31, 2010 at 10:13 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    thats why were all here.:thumbsup:
  14. Jan 31, 2010 at 11:24 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    neutral, not park
    opps...i'm late.
  15. Jan 31, 2010 at 11:32 AM
    ickthus
    ickthus Active Member
    DAVID
    MOBILE,AL
    OC
    2.75BL5100'S/UNDERCOVER
    if you have to back up or pull up alittle, turn the wheel slightly as you do, it will take the torque off and pop right in.
  16. Jan 31, 2010 at 12:12 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I read the manual and didn't catch "the truck will beep if you're not fully engaged in 4WD low". Thanks for the information!
  17. Aug 13, 2010 at 6:44 AM
    CO_Tacoma_0351
    CO_Tacoma_0351 New Member
    Colorado Springs
    06 SR5
    Toytec 3" Lift Airaid Intake 17" Halo Rims BFGs Eclipse Deck
    Thanks for the thread guys! It takes me a combination lock to get 4L engaged. Stop, neutral, park, nuetral, wheels right, reverse, neutral= engaged 4L. Are the gearings just that tight??
  18. Aug 13, 2010 at 7:52 AM
    David K
    It has never been a problem for me (3rd Tacoma now)... as long as you put the tranny in Neutral, as instructed. The rear locker is where it takes a couple of attempts to engage... but with A-TRAC, I don't need the rear locker anymore.
  19. Apr 9, 2012 at 8:00 PM
    taco40
    taco40 New Member
    Josh
    Cedar Falls
    Sounds like you should have about 30 free guys after all that. How's that for a first post? :(
  20. Apr 10, 2012 at 8:40 AM
    David K
    Never need 'Park' in the process of going into L4... Stop, put in N (Neutral), rotate dial to L4, put into D (Drive) and it clicks in then or as soon as you begin to move... The wheel possion is not an issue either, but usually mine are straight.
    To get out of L4, reverse that process.
