4 low issue or not ??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GOTSAND?18, Jan 22, 2020.
  1. Jan 22, 2020 at 10:09 AM
    GOTSAND?18
    GOTSAND?18 [OP] Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    K question guys so I decided to run the 4 low to break it in . I put it in 4 low would not engage .finally got it to engage so I ran a few feet .stopped and had truck in neutral went to 4h would not go out of 4low so I put it in 2 wheel drive heard a clunk and it engage back to 2wd .A little worried that I heard that clunk I didn't go very far maybe a few feet and stopped the truck .Anything I need to be concerned about ?? I tried it a second time again 4low not engaging got it to work a after a few times .this time I was able to switch from 4low to 4high then 2wd no weird sounds or smells (there was no smells the first time I did it ) . what u guys think still breaking in truck is new with only 800 miles or should I bring it up with the dealer ??
    thanks for the inputs .
  2. Jan 22, 2020 at 10:13 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    You can generally hear but not smell 4wd engage. This is normal....
    Taco_Craig and GOTSAND?18[OP] like this.
  3. Jan 22, 2020 at 10:13 AM
    Shellshock
    Iowa
    It’s normal. It takes a bit of finesse to get it to go quick and smooth.
  4. Jan 22, 2020 at 10:14 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    I don’t have a Manuel so can’t really offer help but my auto did not want to come out of 4 lo the first time I used it, drove back and forth, finally disengaged, tried it a few more times seems ok
    GOTSAND?18[OP] likes this.
  5. Jan 22, 2020 at 10:17 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    I've found the slope/angle of my truck plays into whether or not the 2WD/4HI/4LOW switch is "timely" or not
    Also there is typically a "clunk" when switching 2WD/4HI/4LOW, in my experience. I'm no mechanic but I'm guessing it comes from "engaging / disengaging" whatever it does when you switch between drive modes
    SandyTaco4x4 and GOTSAND?18[OP] like this.
  6. Jan 22, 2020 at 10:18 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    How often did you use 4hi or 4lo before this?
  7. Jan 22, 2020 at 10:19 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Must stop and pause exiting 4Lo. (And entering) Once I started doing this no issues.
    Smell? No.
  8. Jan 22, 2020 at 10:27 AM
    GOTSAND?18
    stock
    I have used it a few times only in 4h decided to run it 4l since its anew truck with only 800 miles .
    GreyBaldTaco[QUOTED] likes this.
  9. Jan 22, 2020 at 10:27 AM
    GOTSAND?18
    stock
    thank you guys for all the info .
  10. Jan 22, 2020 at 10:30 AM
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    I use 4hi a bit. for maintenance you need to go to 4 low too?
  11. Jan 22, 2020 at 10:35 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Did you have it in "neutral" when you switched in & out of 4 low? Your supposed too.
  12. Jan 22, 2020 at 10:35 AM
    GreyBaldTaco
    2019 F150 5.0
    Ah there it is, use it some more and itll loosen up and go in easier. Make sure you use 4hi once a month for 10 miles, this is in the manual.
  13. Jan 22, 2020 at 11:49 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Not surprising there was some stubbornness using 4LO for the very first time. Gears, synchronizers and other things are all meshing for the first time. The first few times I went to 4LO, the clunks were much more aggressive. After more engagements and disengagements, it barely makes a sound now.
    I shifted from 4HI to 2WD while parked once, and had a real nasty clunk when the front diff ADD shift fork finally busted the connection loose. Now, I always switch in or out of 4WD while moving, but without any throttle input. That way the parts are moving, and there's no real tension on the driveline while shifting. Much mo' betta.
    MOC221_ and GreyBaldTaco like this.
  14. Jan 22, 2020 at 11:51 AM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    I believe there are also notes on the visor regarding this. :thumbsup:
    GreyBaldTaco likes this.
  15. Jan 22, 2020 at 11:57 AM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    Not sure why you would smell anything but clutch as you have a manual. Also how fast are you going from 2wd to 4lo? that could take longer. I've usually already been in 4hi for a while before i switch to 4lo and it takes almost no time, same when going back. But yes...
  16. Jan 22, 2020 at 12:01 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Stopped, clutch in (all the way).
    The neutral thing is for A/T trucks.
    Tocamo[QUOTED] likes this.
  17. Jan 22, 2020 at 12:03 PM
    Shellshock
    Iowa
    every time mine hasn't gone, its because it isn't *quite* all the way down. an extra nudge and it flips right in.
    MOC221_[QUOTED] likes this.
  18. Jan 22, 2020 at 12:12 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    #7 (^10)
    Clunk is good, you know if worked.
    Swell is likely brakes as a coincidence of the back and forths.
  19. Jan 22, 2020 at 12:16 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    You're going to have a blast with the rear lock too.
    But it'll be OK!
