4 low not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FlyRN, Aug 13, 2020.
  1. Aug 13, 2020 at 2:07 PM
    FlyRN
    FlyRN [OP] New Member
    05 Tacoma TRD
    Hi y’all. I too have searched the forums and found the simple answers but not the right one yet - yes I’ve followed the instructions for engaging the 4 low on the visor. 4 low not working while 4 hi works flawlessly. Took it to the shop. They replaced the transfer case and both position sensors saying either the motor or the fork had failed. Still won’t engage 4 low - it just beeps and now they’re doing further diagnostics. Hoping someone else has some ideas. Ecu? Switch? 2005 v6 TRD extra cab automatic.
    Thanks in advance! Hope I haven’t dug too big a hole by taking it to a non-Toyota tranny shop that’s done good work for me before.
  2. Aug 13, 2020 at 3:57 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    OMG... Before turning the dial to L4, did you put the tranny in N Neutral (not P Park) if an automatic, or fully depress the clutch if a manual?
    eccracer104 likes this.
  3. Aug 13, 2020 at 4:42 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    When I had problems with this the fix was amazingly simple. The sensor behind the clutch pedal that tells the truck whether or not the clutch is fully depressed was just loose or moved back. I can't remember what it was exactly but it took about a minute to "fix". basically even though the clutch pedal was depressed the truck didnt know. I often had to press the clutch start cancel button to start the truck for the same reason. You may have the equivalent problem in the auto?
    When I was having the problem someone also suggested I check the airlines going into the transfer case because they often crack at the end. Mine was cracked. but if you replaced the whole thing, that's probably not the problem.
    Steves104x4 likes this.
  4. Aug 13, 2020 at 6:17 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    He would also have starting issues, if that were the case. Are you having starting issues too, OP? It only starts in neutral, or clutch cancel?
  5. Aug 13, 2020 at 6:32 PM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    My clutch needs to be 100% down to start. Not 95%, not 99%, full send 100% down. Sometimes I still have a mini heart attack thinking my truck doesn't start
  6. Aug 13, 2020 at 7:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
