4 low won’t engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DPorterG67, Feb 26, 2023.
  1. Feb 26, 2023 at 5:29 PM
    DPorterG67
    DPorterG67 [OP] Member
    David
    Wyoming
    2010 Tacoma Access Cab SR5 V6 6 speed manual
    3” lift, American Racing 18” wheels, various other cosmetic upgrades.
    Hello. I am having an issue with the 4 low not engaging. 4 hi works just fine. It’s a manual transmission and I’d prefer not to burn up the clutch when I need to go slowly up a rocky hill or to climb over stuff. I’ve tried all the “tricks” I’ve come across on here, searched the internet, YouTube, and nothing works. Any ideas on where to start looking under the truck?
  2. Feb 26, 2023 at 5:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    GilbertOz likes this.
  3. Feb 26, 2023 at 5:44 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    When in doubt remove the transfer case limit switches and clean them. Make sure the little ball detents press in and out freely as transfer case lubricant can gun them up over time. Reinstall and it could help.
  4. Feb 27, 2023 at 5:24 AM
    DPorterG67
    David
    Wyoming
    Well. While doing a service on it last night I noticed the fluid in the clutch reservoir was low. Close to an inch below the Min line. After filling it and completing the service I went for a test drive. Went to a dirt lot and tried “standing” on it. I was lifting myself out of the seat with the pressure I was applying to the clutch pedal. And…it worked! Went right in to 4low!
    Thank you all for your suggestions!
  5. Mar 1, 2023 at 8:40 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Glad you got it working, but the issue had nothing to do with the fluid level. There is a little button switch that the pedal lever presses when all the way down, that's the switch that the computer looks for to allow you to shift into 4lo. If you're having to stomp down on the pedal that hard, you're beating on your master cylinder and need to adjust the switch position to where it engages just at the bottom of the natural pedal travel. Should be able to adjust it by screwing/unscrewing the nuts that hold it in its mount.
    amyracecar and shaeff like this.
  6. Mar 1, 2023 at 10:59 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    This. You shouldn't have to literally stand on the thing. Time for some adjustment, and also look into why you were so low on fluid. Check for leaking up near the clutch pedal both inside and out, check you lines, check the slave, and if V6, check the accumulator (and then remove it lol).
  7. Mar 1, 2023 at 11:15 AM
    DPorterG67
    David
    Wyoming
    Adjustment has been made. Wasn’t aware that button was even there! No longer need to press the clutch down so hard. Not sure about the fluid level. I can’t find any leaks. I guess I assumed the mechanics at the dealership were checking it. I had been using my local Toyota dealership for service due to not enough room in the garage to pull the truck all the way in. And winters in Wyoming are not the best time to do an oil change in the driveway. Garage problem fixed. Back to doing it myself.
    Thanks again for all the info and advice!
    risethewake and shaeff like this.
