4.o v6 engine noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shirttail 791, Feb 2, 2018.
  1. Feb 2, 2018 at 5:37 PM
    shirttail 791
    shirttail 791 [OP] Member
    Don
    shenandoah valley VA
    SR 5
    2013 with 4.0 v6 engine has same noise I have been reading about .Seems to be on left side .Have 27,000 miles on it & noise has always been there . Don't know if it will last or not . Does anyone have same engine with more miles that still has the noise . Would like to keep it if I can get maybe 100,000 out of it . THANKS
  2. Feb 2, 2018 at 5:38 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    I would be more worried if your motor wasn't making noise when it was running.
    Edit: in all seriousness, im assuming your talking about a ticking? If so its Normal.
    MadDaddy likes this.
  3. Feb 2, 2018 at 6:33 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  4. Feb 2, 2018 at 6:47 PM
    badger
    badger Well-Known Member
    07 SR5
    If your Tacoma is not chirping, rattling or ticking, check your tach! Most likely the engine has died, and will require restarting.
  5. Feb 2, 2018 at 9:51 PM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    Many of us have considerably more miles than that on our Tacos. Almost 180k here and no issues with the engine besides normal maintenance.
  6. Feb 2, 2018 at 10:02 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Could you describe the ruckus?
    Monkeybutt2000 likes this.
  7. Feb 3, 2018 at 7:40 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If it’s ticking, it’s most likely normal. Most Tacoma motors are noisy. Mine has 71k miles and is noisy. Sometimes more noisy when really cold.
  8. Feb 3, 2018 at 7:55 AM
    NM Lance
    NM Lance Well-Known Member
    Does it sound like a knock? I have this issue before it reaches operating temp. It sounds like the engine is running too lean upon warm up, but that is only a guess.
  9. Feb 3, 2018 at 8:22 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Our trucks making unknown noises? No way......
  10. Feb 3, 2018 at 9:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
