4" or 6" Rough Country lift?
Discussion in 'Suspension' started by Project.Shadow, Jan 22, 2017.
  1. Jan 22, 2017 at 1:13 PM
    Project.Shadow
    Project.Shadow [OP] Active Member
    Cal
    2015 Black Tacoma TRD Sport
    3" leveled, Go Rhino led installed bullbar
    I have been shopping around for a couple weeks now and have been looking at everything from Tuff Country's 4 inch lift to an Icon Stage 3 lift;) and i think what im deciding on is Rough Country's 4" or 6" lift. But i dont know which one is better for the truck or the difference between them other than the added 2 inches, thank you:help::help::help:
    ChadsPride likes this.
  2. Jan 22, 2017 at 1:19 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Don't you think you could condense this to one thread on this topic? You have like what 3 of them now floating around the same suspension questions???
  3. Jan 22, 2017 at 1:22 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  4. Jan 22, 2017 at 1:28 PM
    snox31
    snox31 Active Member
    rich
    Sheboygan wi
    2011 trd off road
    Icon stage 3 would be the best choice out of what you have listed for choices
    Oreo Cat, ChadsPride and EDDO like this.
  5. Jan 22, 2017 at 1:31 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Don't do a rough country lift. If you want a 4 or 6" lift spend a lil more and get a better one.
  6. Jan 22, 2017 at 1:36 PM
    Project.Shadow
    Cal
    or you could just answer the question and you wouldnt see anymore:wink: instead of this pointless reply
    06TacoTacoBurrito and ChadsPride like this.
  7. Jan 22, 2017 at 1:36 PM
    Project.Shadow
    Cal
    cant afford that lift
  8. Jan 22, 2017 at 1:37 PM
    Project.Shadow
    Cal
    could you tell me whats wrong with it? and i really cant spend $2000 currently for a lift and thats not even adding in the labor costs
  9. Jan 22, 2017 at 1:39 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Ah okay Good Luck with whatever you go with and enjoy the Junk Country Lift. Time to unsub and my little advice is " Buy once and cry once. " And remember you get what you pay for.
  10. Jan 22, 2017 at 1:46 PM
    snox31
    rich
    Sheboygan wi
    2011 trd off road
    I have been doing hours of reading about lifts and from what I have read so far is a nice affordable lift get a 5100 set up .as far as a db lift the rcd that comes with 5100 rides good and the CV and tie rod angles are all good .bds with fox coilovers is awesome too but cost way more.i am just saving to buy the fox with camburg arms .if you can't afford quality suspension I suggest to save until you can do it right the first time
    strongrob and RexsTaco like this.
  11. Jan 22, 2017 at 1:47 PM
    Project.Shadow
    Cal
    I was just asking people for a little advice :thumbsup:sorry i posted so many times lol...
  12. Jan 22, 2017 at 1:48 PM
    Project.Shadow
    Cal
    i agree, just a little impatient lol, should i save up for the icon stage 2 or save up even longer for the stage 3:annoyed:hahaha
  13. Jan 22, 2017 at 1:50 PM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Yer new here aren't yah.
    o_O
    The better performance lift of the ones you listed is the Icon.
    If you can't afford it don't list it as an option.
    Ifen your planning on mall froadin then the Rough Country is the lift for you.
    There are other affordable performance lifts similar to the Icon.
  14. Jan 22, 2017 at 1:57 PM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    It mostly depends on what you're trying to achieve, are you looking better than stock performance off-road? Higher load capacity? Planning to run a larger tire and wheel? Planning on adding armor? (skids, plate bumpers, sliders)
  15. Jan 22, 2017 at 2:04 PM
    Project.Shadow
    Cal
    mall froadin?:rofl:
    looking to fit bigger tires. and have better offroad performance. thank you for asking real questions!!!:bowdown:
  16. Jan 22, 2017 at 2:13 PM
    snox31
    rich
    Sheboygan wi
    2011 trd off road
    Just be patient and read and take in all the info that you can and in about a year you will be able to make a choice that will work good for you. I like reservoir shocks because I like the bling factor and when I go to the dunes I will rip up the whoops and jumps
  17. Jan 22, 2017 at 2:20 PM
    Project.Shadow
    Cal
    Thanks for the advice, will do. btw what suspension do you have?
  18. Jan 22, 2017 at 2:27 PM
    snox31
    rich
    Sheboygan wi
    2011 trd off road
    I was set on a 6 " bds but after reading and knowing what I do with my truck I am going with fox 2.5 and camburg a arms probably from headstrong it will be 2500 for that set up and I can run 16" wheels with that set up .I could get away with 5100 most of the time but once I hit silverlake sand dunes a couple times a year i think the fox set up will be more fun
  19. Jan 22, 2017 at 2:33 PM
    BORNWILDGUY
    Rich
    Florida
    What's wrong with it is it doesn't put your cv angles back to stock angles like most db kits. Also look at the tierod angles. The blue truck has a rough country and the red one has a rcd. Just look at the cv angles and if you still want to use rough country go ahead but I would spend a lil extra on something else.
  20. Jan 22, 2017 at 2:33 PM
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    I'm running Bilstein 5100 front and rear currently using Tacoma TRD Sport springs with the front set at 0.85 and 1/2 spacers, planning to swap them out for OME 885 springs. The rear has a two leaf progressive add a leaf. It lifted the front about 2.5" and the rear 2" and gave me plenty of clearance for a 265/75/16
