4 pin Tweeter Wire Harness for 3rd gen non JBL
Discussion in 'Audio & Video' started by lytic, May 21, 2019.
  1. May 21, 2019 at 9:12 AM
    lytic
    lytic [OP] Member
    2019 DCLB TRD Offroad
    I was looking for a wire harness to use at the tweeter connection to avoid cutting or splicing the factory cables when I install some component speakers in my 2019 non JBL system.
    After some searching I found these for ~ $3.50 single/$7 pair:
    https://www.sonic-x.com/product/4-pin-wiring-harness-adapter-speaker-cable-for-toyota/
    I had not seen mention of these anywhere on the forum. Has anyone used these, ordered from sonic X etc...? They look correct but I'm not an expert and a second opinion would be appreciated.
    They also have the what looks to be the harness for the door speakers for $4.12 single/$8.24 pair here:
    https://www.sonic-x.com/product/hig...aker-cable-for-toyota-mitsubishi-subaru-bass/
    Worth a look around the site, they may have some other harnesses folks where looking to find.
    So what do you think, do these look correct?
    Thanks!
  2. May 21, 2019 at 9:34 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Sure looks right!
    I’m so glad someone besides ********* finally offers them! They run $29/pair from them.
    Never heard of sonic-x. Ships from Hong Kong so no clue what you’re getting into. I’d pay with something other than your main credit card (or use PayPal if they accept it?) and be prepared to lose $7 lol.
  3. May 21, 2019 at 10:04 AM
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
    That tweeter connection will always confuse me haha. So basically it's positive in and out and negative in and out. So if I used this connector and just twist/solder the red to the red and the black to the black, and connect to the plug it would just bypass the tweeter, right?
    Could also take output from an amp and wire them directly to one set of the +/- on this plug and it would send the signal to the door speaker... just have to guess which set of +/- would be the right ones..?
    Do58 likes this.
  4. May 21, 2019 at 11:05 AM
    lytic
    lytic [OP] Member
  5. May 21, 2019 at 12:25 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    you are correct in both of your thoughts. one set comes from the radio, one set goes into the door. The factory tweeter acts as a bridge between them.
