4" RCD Lift with OME 886 Coils probblems
Discussion in 'Suspension' started by Catron, Oct 25, 2010.
  1. Oct 25, 2010 at 4:07 AM
    Catron
    Catron [OP] Member
    Texas
    2010 DC Tacoma TRD 4X4
    Hello, this is my first post here and still learning much as I go.
    I just had a 4" RCD lift installed on my truck and also replaced the factory front springs with OME 886 based on how my front end dropped when I put on the front replacement bumper and winch.
    The problem or challenge I have now is that the front end is 2.25" higher than the rear. There seems to be significant angles on the axles and upper control arms
    What are your thoughts? Too much angle? Do I need to go back to the stock springs? I really figured I would need the heavy duty springs with the additional 245lbs of weight up front. The front end also tends to wander and float more now
    Here is a pic of the truck.
  2. Oct 25, 2010 at 7:31 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    wow..way too much of angle. cv boots are not the only problem. most people forget the angle of your tie rods put a great deal of added wear on your rack and pinion steering.
  3. Oct 25, 2010 at 7:33 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    that is why you dont combine lifts...
  4. Oct 25, 2010 at 9:45 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    I thought your supposed to rock out the stock springs with these kits?! I think the 886 springs are your problem. Angles are severe...
  5. Oct 25, 2010 at 9:47 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Exactly.
  6. Oct 25, 2010 at 9:50 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    lose the 886s... if you must use aftermarket springs try 884s or even eibach 1.6s... all I know is that the additional lift is the problem... 886s are heavy duty springs and even with the additional weight up front they are obviously not sagging or compressing as much as you need.
    and everyone is right...combining lifts is usually a problem
    Out of curiosity do you also have a body lift?
  7. Oct 25, 2010 at 12:35 PM
    Kdawwwg
    Kdawwwg Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    i added about 1 extra inch with 5/8 spacers, an my Axel angles are know were near yours ,i think that 1.6 ebiach spring would be perfect with your front weight,bet you would get a good inch plus.
    an for the rear i added a 1.5 inch add a leaf,for a total of 5.5 in rear,sitting at about 42" ground to fender at all fours
  8. Oct 25, 2010 at 12:38 PM
    08pretaco
    08pretaco IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Another GREAT example of why we DO NOT stack lifts!
  9. Oct 25, 2010 at 12:39 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Do you have the 5100's set at 0?
  10. Oct 25, 2010 at 12:41 PM
    08pretaco
    Oliver
    az
    yes sir! do you? I am wanting to put a small .5" preload though
    I should have said this is why we dont stack lifts of large lift numbers. I mean adding a little something like <1.5" on something like this sure why not! But adding 886's coil I dont think was right...
  11. Oct 25, 2010 at 1:02 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    what ever the problem is you better fix it before you fuck up your cvs
  12. Oct 25, 2010 at 1:03 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Sorry. I was asking the OP. I didnt clarify. Because maybe he is running 886's + 5100's at x".
  13. Oct 25, 2010 at 1:06 PM
    08pretaco
    Oliver
    az
    Oh i looked on RCD website and it looks like the shocks are not adjustable but IDK :confused: and looking at his pictures I dont see the groves for the snap ring to go into to adjust them either. All the descriptions say that they are custom 5100 shocks...
  14. Oct 25, 2010 at 1:12 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Interesting. I wonder if 885's would still be too much?
    And I dont have 5100's. Got Fox 2.0's.
  15. Oct 25, 2010 at 1:16 PM
    cantac09
    Hugh Jass
    Saskatchewan
    tundra
    stock
    no the shocks arent adjustable. he should try with just the stock coils and see how it is.
  16. Oct 25, 2010 at 1:22 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea. He is unclear if he put the bumper on when it was stock and then added both lifts at the same time or put the lift, then bumper, then 886's.
  17. Oct 25, 2010 at 7:59 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    lose the bumper and change the spring back to stock
  18. Oct 25, 2010 at 8:16 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Really helpful!
  19. Oct 25, 2010 at 9:06 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    It doesn't look to severe...
  20. Oct 25, 2010 at 9:11 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I noticed that your running Billy 5100s up front. Maybe you could go back to stock springs and set the billys at .85" of lift to counter the bumpers weight...not sure though. Combining lifts isn't a good thing to do :eek:
