4" RCD Lift with OME 886 Coils probblems
Discussion in 'Suspension' started by Catron, Oct 25, 2010.
  1. Oct 25, 2010 at 10:53 PM
    #41
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    08pretaco...not you...jr114
  2. Oct 25, 2010 at 10:54 PM
    #42
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    wow someones aggro. not spreading false info and not stating to know for sure. i just posted some info that i had. you get the 4.5" of lift through the spindle. thats why they replace it. then why do the 5100s that i had have the rcd logo on there stating that they were made for use with the rcd kit? relax. were all here talking sharing info trying to figure things out. thats what this forum is for. and why would bilstein use rcd for distribution of a shock? pretty sure they dont need rcds help theyre big enough on their own. if theres something im completely missing, then thats fine please inform me. but dont get all aggro trying to make it seem like were spreading "false" info on purpose. did you read all of the posts and see the ideas and theories that were thrown out or did you just see what you wanted to and rant?
  3. Oct 25, 2010 at 10:54 PM
    #43
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Oh haha cause you included me in the quotes :( I wasnt yelling at you either just felt like using BIG LETTERS LOL
  4. Oct 25, 2010 at 10:58 PM
    #44
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    two different kits man... the bilsteins with the drop bracket kit is not adjustable and longer than the RCD bilstein shocks you have... thats a fact, don't know why its RCD and Bilstein... but I'm sure it has to do with design/ownership etc... but that doesn't matter.
    The Bilstein 5100 shock on the RCD drop bracket kit is NOT adjustable
    edit: I think RCD is Bilstein or Bilstein is RCD or RCD contracts with Bilstein to provide shocks... maybe they are a distributor, but their site say bilstein shock experts
  5. Oct 25, 2010 at 11:02 PM
    #45
    jr114
    Jon
    SoCal
    Truck
    thanks for the info. i was not trying to distribute improper info, just thought id share with what limited info i had. i assumed that cause the shocks were stamped with rcd that they were for the kit. but hey to assume makes an ass out of u n me. well mainly me in this case. haha..thanks again for setting me straight
  6. Oct 25, 2010 at 11:05 PM
    #46
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    to the OP
    the problem is clearly that you have too much lift for the RCD to handle... the kit doesn't drop the diff far enough to get 6+" of height without affecting cvs you need to either
    1. get softer springs (884s, eibach 1.6s, etc)
    2. get stock springs and lose the bumper (or accept lower height)
    3. lose the rcd kit, 886s and get a 6" db kit
    otherwise you're gonna eat your cv pretty damn quick
  7. Oct 26, 2010 at 5:52 AM
    #47
    Catron
    Catron [OP] Member
    Texas
    2010 DC Tacoma TRD 4X4
    Thanks all. I really appreciate the input. The height should be ok as it would be 2.25" over stock since the RCD lift puts all the angles back to stock. Even so, I feel its too high. I plan on having the stock coils put back on Friday. I will probably go with the 1.6 eibach coils and rear 1.5 springs. Unless anyone know where to get stiffer stock size coils?
    Thanks again for the information and help!
  8. Oct 26, 2010 at 12:39 PM
    #48
    Catron
    Catron [OP] Member
    Texas
    Its okay you don't like the bumper. Personally, I think its wicked bad ass and the last thing I will do is take it off. It is completely custom and will run over a ton of stuff! I was simply looking for help on the front lift while utilizing the bumper.
  9. Oct 26, 2010 at 2:43 PM
    #49
    Catron
    Catron [OP] Member
    Texas
    Luckily I'm not driving it right now and will have the factory springs back on till I can figure something else out.
  10. Oct 26, 2010 at 2:47 PM
    #50
    jr114
    Jon
    SoCal
    Truck
    and thats totally cool. our trucks are an extension of our personalities. the only thing i can think of that may help the front end problem is to try a different spring. remember the 885 is designed to give roughly 3" of lift on their own. try a different spring rate, 883, 884, eibach? one of those may be the right combo your looking for.
  11. Oct 26, 2010 at 3:37 PM
    #51
    Chewy
    Chewy Member
    MT
    08 4x4 SR5
    Catron here are a couple links that might help.
    1st is a chart for the various OEM springs. It gives you load rates and lengths. For the Billies it appears springs 883, 884, 885, & 886 will work. From the chart you will see 883, 884, & 885 all have the same spring rate just different lengths. Keep in mind the stock spring is 14 inches long and I believe a spring rate that is 40 pounds less than the 883/884/885, individually, so 80 pounds total.
    http://www.cruiseroutfitters.com/tech_OME_coils.html
    2nd link will help you convert mm's to inches.
    883's are 14.76 inches.
    http://mg-jewelry.com/mmtoinches.html
    I can't remember the exact numbers but I believe the Eibach is approximately 1.5 inches longer then stock and has a 30 pound heavier spring rate than the 883, 884 & 885. (based on your last comment you may have found that information in a quick search).
    Based on the size of your bumper the eibach might be your best option or 884’s may work also. Also whatever spring you do use, will probably settle a bit, but the 885's and 886's still might be too much lift.
    Another issue is will/if the RCD drop kit billies can handle the extra spring rate, but it seems like a lot of guys have luck using them with the 5100's so if they are built the same you should be ok. Obviously that is just a hunch; I have not formally questioned or researched if there are any internal structural differences between the two shocks. Might be worth a quick email to Bilstein, if they are willing to answer your question.
    I really like where your heads at; I spent a ton of time researching this exact scenario over the weekend. Thinking about running the RCD kit with an aftermarket bumper also (although not nearly as heavy as yours) and I do not think the stock springs will handle the extra weight. For my situation I’m trying to decide if the 883s or 884s would be better.
    The bumper looks awesome and to each his own. Keep rocking it!!!
    Please, please, keep us posted on what you end up doing and the results. I know others would enjoy a full report – ride quality (stiff/smooth/spongy), any vibes, drive habits, etc.
    Wow some of you guys on here get a little excited…….relax and drink a damn beer (or two)!! :)
  12. Oct 26, 2010 at 3:54 PM
    #52
    Chewy
    Chewy Member
    MT
    08 4x4 SR5
    Hey Catron a couple quick questions.
    What is the cover on your rock panels, bed liner? Also what size wheels and tires are you running?
    Thanks bud and best of luck on your project.
    Again please keep us posted!!!!
  13. Oct 27, 2010 at 5:03 AM
    #53
    Catron
    Catron [OP] Member
    Texas
    Its bedliner on the rockers. Wheels are 17x8.5 -6 offset 4.5 backspace. Dale Earnhardt Jr. Cannon wheels. They make two exact wheels with similar measurements. One for chevy and one for toyota. They are not interchangeable. Tires are 285/70/17. I kept the tires simple for the first run and will go a bit bigger next time
    Thanks again everyone for the great input! I will post more pics and info when I get it right.
  14. Oct 28, 2010 at 4:13 PM
    #54
    benq
    benq Active Member
    Surprise, AZ
    2010 Doublecab, Shortbed, TRD Offroad
    Borla Turbo XL muffler TRD air filter
    @Catron Thanks for taking the time to post. It really helps newbees like myself who are considering any lift kit. The responses are great too. There are some things I don't mind not learning firsthand.
  15. Oct 29, 2010 at 10:25 AM
    #55
    Catron
    Catron [OP] Member
    Texas
    Ok, the stock coils will be back on in the morning. I have a question about correcting the front end sag.
    Two options (not removing the front bumper so that is not an option :))
    1. Stack the lift with new Eibach 1.6" coils and add a leaf 1.5" in the rear. The front end will end up being slightly lower (only slightly with the added weight) than the rear. This will also add a little height to the front and rear.
    2. Add a 1/4" top spacer to the factory coil. This should give me 1/2" on the front end to help the sag. It will still be slightly (only slightly) lower than the rear.
    My third option is dead since I have been unable to find heavy duty stock size coils.
    What are your thoughts?
  16. Oct 29, 2010 at 12:16 PM
    #56
    Kdawwwg
    Kdawwwg Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    #4 OPTION :i added 1/4 plus 3/8 top spacers on driver, 3/8 top spacer on passenger, stock sport spring,got almost 1" with that combo,an no more taco lean
    i would say you can add up to 3/4 of spacer an still have good CV angles
    keep the stock spring, as this kit RIDES so smooth
    REMEMBER the more you lift,the available down travel you take away
    as i just installed limiting straps on mine i know i have 2 1/2 inch's of down travel[which is still good,keeps the ride smooth,no harsh bumps] if you have aftermarket uca[like light racing] that don't have stops built in ,your ball joint will droop in to your spring ,an CV boot will hit lower control arm[at least on mine it did],straps fixed this[rcd said they do not use the shock to stop droop]
    good luck
  17. Oct 30, 2010 at 5:01 AM
    #57
    Catron
    Catron [OP] Member
    Texas
    Kdawwg, You currently have the RCD lift on your truck? What was causing your front end droop, aftermarket bumper?
    Did you use any additional lift in the rear?
    Wouldn't the Eibach coils take care of everything in the right way? Providing a bit more lift and support in the front while upgrading the factory TRD shocks?
  18. Feb 25, 2013 at 9:33 AM
    #58
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    So you can't see it in this picture but what UCA's would you recommend or use in order to get my camber right? I ran into this same problem and now I'm in this boat..
  19. Mar 27, 2013 at 8:03 AM
    #59
    SuthrnTaco07
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    So I did something similar with the ProComp 6" lift and the RCD 4.5" lift Shocks. Started with the 886's and the wrong UCA's.. My ride was too stiff and was sitting at just over 46" from ground to fender with worn out 35's.. now I bought the 884's and had it aligned and now I have AMAZING ride quality and 42" same measurement on driver side.. So I added a 2" top plate spacer on top of the coil over not to loose ride quality and now i'm sitting back at 46"!!! WTF!! What do I do!? I'm hoping that after alignment everything will be PERFECT but we'll see!
