4 runner exhaust system...
Discussion in 'Technical Chat' started by hetkind, Oct 1, 2011.
  1. Oct 1, 2011 at 6:44 AM
    hetkind
    hetkind [OP] Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    My SIL bought this POS, beat to death 90 4 Runner with a rusted off tailpipe and a plugged cat converter.
    I was going to order a cheap glass pack and have a local muffler shop weld the glass pack on to the head pipe in front of the cat converter now sits and bend to the rear bumper...and my only question is what size glasspack pipe size should I order. My gut says 2"...
    And the only reason I would like to order one is advance is I don't know if the local shops stock glasspacks.
    Howard
  2. Oct 1, 2011 at 6:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You might be better off having the exhaust shop make a new exhaust. IT shouldnt be very expensive. A decent muffler should be about 30 to 40 bucks.
  3. Oct 1, 2011 at 7:11 AM
    jcemitte
    jcemitte Livin' the taco life
    Jake
    Tulare CA
    04 Taco SR5 5 lugger
    Deck Plate mod, Knock Off Flowmaster,billet grill, alpine HU w/kicker amp and pheonix gold 12" sub stock componets
    Were you wanting to go with the glass packs cause you wanted a poppyish exhaust or were you trying to go a different direction? if your just trying to get in runnin i would just have them return it to stock. maybe about $100 or less but itll be worth it to do it right.
  4. Oct 1, 2011 at 8:56 AM
    hetkind
    Howard
    Johnson City
    Let me try this again....the cat converter is plugged, the exhaust system is MISSING at the back of the muffler and the head pipe looks nasty:) To do this exhaust system back to stock is about $500....
    However, Rock Auto shows a 2" glasspack for it, but it is not a bolt on, since there is a flange at the cat convertor and the glass pack is a slip on.
    So, back to the drawing board.
    Howard
