4 Runner Trail Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 07toyota1991, Apr 16, 2018.
  1. Apr 16, 2018 at 5:27 AM
    07toyota1991
    07toyota1991 [OP] Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    Purchased a set of 2017 4runner trail edition wheels over the weekend that had the tpms sensors in them already. I just unbolted my others and bolted these up. I tried to program the TPMS sensors to my Tacoma and cannot seem to do so. Any ideas what could be causing this. I have a 2016 TRD OF which had aluminum wheels, I figured it would be fairly straight forward.
  2. Apr 16, 2018 at 5:34 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    When you say program the sensors, what did that entail. I believe you need to have the sensor ID and something like Techstream. Were you just pushing the reset button on the truck, or was this with the proper equipment and its not taking?
  3. Apr 16, 2018 at 5:41 AM
    07toyota1991
    I was using a system that came from Snap On. The frequency on the 4runner wheels were different that what the computer was reading for a 2016 Tacoma, not sure if that could be the issue...
  4. Apr 16, 2018 at 5:44 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    Just take it to a dealer. They will fix it in 15 minutes. It’s going to cost you though.
  5. Apr 16, 2018 at 5:50 AM
    07toyota1991
    Really was wanting to avoid the dealer option as I have heard that can cost a couple hundred dollars...
  6. Apr 16, 2018 at 5:56 AM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    I do not know if the TPMS are different for the Tacoma and 4Runner, but it may be worth a shot to try a local Discount Tire. They should be able to scan the TPMS and then connect to you OBD-II port. Probably a cheaper option than the dealer.
  7. Apr 16, 2018 at 6:00 AM
    07toyota1991
    I am curious if the Tacoma spare sensor could be throwing things off. I am sure someone has to have some insight. I will try a local shop on the way home and see what they say
  8. Apr 16, 2018 at 6:03 AM
    scottsglock29
    Scott
    Wisconsin
    I do not think that the spare has a sensor in it.
  9. Apr 16, 2018 at 6:13 AM
    07toyota1991
    Spare definitely has a sensor. My 2007 had a spare sensor..
  10. Apr 16, 2018 at 6:21 AM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    My 2017spare doesn't have a sensor!
  11. Apr 16, 2018 at 6:25 AM
    07toyota1991
    Strange! Maybe need to drop it and find out then...
  12. Apr 16, 2018 at 6:27 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The spare doesn't have a sensor. Only the early second gens did (not sure which year they stopped)
    07toyota1991[OP] likes this.
  13. Apr 16, 2018 at 6:28 AM
    07toyota1991
    That maybe my problem. I was trying to read a spare sensor and it wouldn't read!
    EatSleepTacos likes this.
  14. Apr 16, 2018 at 6:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Doh! There's your problem! :homer:
  15. Apr 16, 2018 at 6:54 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    2008 or 2009 was the last time the Tacoma had a Sensor on the Spare.
  16. Apr 16, 2018 at 9:45 AM
    07toyota1991
    Another problem has occurred. I was able to get the light turned out, however the pressures are not reading on my info system.
  17. Apr 16, 2018 at 9:48 AM
    scottsglock29
    Scott
    Wisconsin
    The pressures will show up after driving around for awhile. Need to put some miles on them.
    shakerhood likes this.
  18. Apr 16, 2018 at 9:50 AM
    07toyota1991
    Ok I wasn't able to do so on lunch. I will when I leave work. Do I need to hit the reset button?
  19. Apr 16, 2018 at 9:54 AM
    scottsglock29
    Scott
    Wisconsin
    I did not have to hit a reset button when I got my new wheels/tires and TPMS put on last week. I just drove it, and then the pressures appeared. It may take 10 miles or so. I do not think that there is any set mileage when they will show up.
  20. Apr 16, 2018 at 10:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    Spare sensors ended during the 2009 model year. So some '09's do, some don't.
    But '10+ do not.
