4 runner vs tacoma
Discussion in 'Performance and Tuning' started by TXpro4X4, Sep 15, 2014.
  1. Sep 15, 2014 at 7:01 PM
    TXpro4X4
    TXpro4X4 [OP] Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Why does the 4 runner have more horsepower than the taco?
    Both have same engine 4.0. For the v6 anyway.
  2. Sep 15, 2014 at 7:14 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Different engines. Tacoma has the 4.0 VVT-i and the 4runner gets the 4.0 with dual VVT-i.
  3. Sep 15, 2014 at 7:15 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Not only does it have more HP.... Its weaker internally too.
  4. Sep 16, 2014 at 11:53 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    On my sales slip it says dohc is that not the same?
  5. Sep 16, 2014 at 12:06 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    The 4 runner can vary the cam timing on both intake and exhaust I believe, the tacoma can only vary the intake timing.
  6. Sep 17, 2014 at 7:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This applies only to the newer 4Runner and FJ. The previous generation had the same 1GR across all three platforms.
    The '03-'04 model 4Runner, has a different VVT-I intake pickup for the cam phase sensor.
  7. Sep 17, 2014 at 5:45 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Thank you.
    Wounder why they didnt (up) all.
  8. Sep 20, 2014 at 9:31 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Based on what data?
  9. Sep 20, 2014 at 9:51 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The 4Runner is heavier at 4800 lb curb weight vs 4100-4200 lb for the Tacoma, so the 4Runner gets the costlier dual-VVTi version to maintain an acceptable performance level.
    Beyond variable cam sprockets, the dual-VVTi version has more complicated (and quieter) hydraulic roller rocker valve lifters in lieu of solid bucket lifters on the single-VVTi engine.
  10. Sep 20, 2014 at 10:19 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Ok, but maybe that's what needs to come. A lot of people complain that the taconeeds a bit more power. Although I'm happy, more is better in this instance.
  11. Sep 20, 2014 at 10:25 PM
    KenLyns
    Belly of the Beast
    The 3rd gen Taco is expected to get the former RAV4's 3.5L 2GR-FE engine, good for at least 276 hp.
    (The prev-gen RAV4 as you can expect was quite quick in a straight line.)
  12. Sep 20, 2014 at 10:26 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    If so is the engine dual vvti?
  13. Sep 20, 2014 at 10:43 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Toyota's. The dual vvti 1gr has 5 balance weights instead of 9 for weight reduction in order to get better mpg. Also is weaker as it implements a 20wt oil fill from factory. The pistons have a cast holes on the bottom of the piston head near the pin bosses, again, to reduce weight. The engine does have some cool stuff on it to make it somewhat of an upgrade. Bigger throttle body, direct injection, chrome plating on the compression ring to be compatible with the planned 20% ethanol mixture, windage tray.
  14. Sep 20, 2014 at 10:45 PM
    KenLyns
    Belly of the Beast
    ^No direction.
  15. Sep 20, 2014 at 10:59 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    your right I looked on my pdf and the injector was moved closer to the intake valve. thats what I get for going off memory alone.
  16. Sep 21, 2014 at 10:38 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Is it dual vvti?
  17. Sep 21, 2014 at 3:41 PM
    KenLyns
    Belly of the Beast
