4 runner wheels on my truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by J.A.92, Jan 12, 2020.
  1. Jan 12, 2020 at 12:17 PM
    J.A.92
    J.A.92 [OP] 97 Tacoma 4x4 lx 5 speed manual.3.4L
    Juan
    1997 Tacoma 4x4 lx xtra cab.3.4
    07C5B960-1FDD-420F-912D-6A3666D0B733.jpg Hi I saw my friends 4 runner had the same wheels as my truck but were an inch bigger.would those work for my mini truck?
    cruiserguy likes this.
  2. Jan 12, 2020 at 12:17 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    If your truck is a 6-lug, then yes they should work. If you are talking about the green Tacoma in the photo, then yes, they will definitely work!
    Hamer95USA likes this.
  3. Jan 12, 2020 at 12:21 PM
    J.A.92
    Juan
    They are a six lug.Just have never heard of anyone doing so wasn’t sure if they were compatible.
    PennSilverTaco likes this.
  4. Jan 12, 2020 at 12:22 PM
    PennSilverTaco
    Charlie
    You'll have to get appropriately-sized tires, but I see people put T4R wheels on Tacos (and Taco wheels on T4Rs) all the time!
  5. Jan 12, 2020 at 12:26 PM
    J.A.92
    Juan
    Oh really! I wouldn’t mind having an inch bigger wheel!
  6. Jan 12, 2020 at 2:11 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
  7. Jan 12, 2020 at 4:21 PM
    J.A.92
    Juan
  8. Jan 12, 2020 at 5:08 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    If you only plan on using stock sized 265-70-16 or 265-65-17 tires, its fine. But I hated the way it brought the tires in so much, so it wasnt for me. And I think wheel spacers are sketchy, but thats an argument for another day.
  9. Jan 12, 2020 at 5:17 PM
    J.A.92
    Juan
    265 yeah.Im running 235 right now.The wheels are mint.But thought 1 inch bigger wheel and a 265 tire would look bitchen.
  10. Jan 12, 2020 at 5:25 PM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    B2314D94-293B-4368-A5DC-09BCF56ECA3C.jpg I run 16 inch 4runner wheels on my 1st gen with 265/70/16 haven’t had any problems.
  11. Jan 12, 2020 at 5:30 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    Can some one explain why backspacing would be a problem. Backspacing kinda confuses me. Im planning on lifting it and putting 285/75/16 in the next year.
  12. Jan 12, 2020 at 5:39 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    You're really going to have to post the exact wheel your asking about. All different generations and sub models have different specs. There has to be about 10 different 4 runner wheels.
    Area51Runner likes this.
  13. Jan 12, 2020 at 5:41 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    To far in aka positive +bs and a 285 or wider will most likely be to close or rub on upper control arm.
    To far out negative -bs makes the tire tend to rub the fenders. And ads additional stress to all moving parts via leverage.
  14. Jan 12, 2020 at 5:43 PM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    Read this first. Standing by to answer any questions that may arise.
    https://www.autoanything.com/resources/wheel-offset-vs-wheel-backspacing-explained/
    This is a very good laypersons explanation. If you want a deeper understanding and geometry at play, check out the above link.
  15. Jan 12, 2020 at 5:46 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    2001 4 Runner wheels 265/75/R16. No problem, but they are not A/T tires (Michelin street tread). You might get a rub if you have any type of tires with aggressive tread that sticks out off the sidewall.
  16. Jan 12, 2020 at 5:48 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    OP if you're asking about a wheel that looks exactly like yours but is 16 instead of 15"?
    The 16s are actually what should have came stock on your truck. 15s came on 89-94 pickups.
    Anywho the 16s stick in 4mm more. And should clear just fine w a 265.
    But if he is your buddy just bolt one on the front, spin it and check clearance.
  17. Jan 12, 2020 at 5:52 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    See the link I posted above.
    If the wheels you want are off a 3rd gen 4Runner (1996-2002) they will have the same backspacing as what you have now. If they are the ones that look like your current wheels, they will work fine.
  18. Jan 12, 2020 at 5:58 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    No, 1995.5 to 2000 Tacoma's did come with 15 inch wheels. 16 inch wheels started in 2001 with the TRD Off Road package. But, you could get these wheels as an option without the TRD Off Road package. OP's truck is a 1997 Tacoma LX which came with 15 inch wheels and 31X10.5R15 tires. Here is a link to the 15 inch Tacoma wheels OP may have:
    https://www.autorimshop.com/toyota-...MIw9zv68D_5gIVycDACh3iEQA5EAQYASABEgIzjPD_BwE
    1995.5 to 2004 4X4 and Pre-Runner 6-lug Tacomas came with the following tire sizes: 225/75/15, 265/75/15, 31X10.5R15, 265/70/16. Again, 16's came out starting with the 2001 TRD Package, but you could get these as an option without the TRD Package starting in 2002.
    Hamer95USA and 04Pre_Runner like this.
  19. Jan 12, 2020 at 6:24 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    15s came on my 2000. I think the 16s came on 4runners. Possibly could have been an upgrade at the dealer for the 16s
  20. Jan 12, 2020 at 6:34 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    Thanks for the help man
