4" Spindles (with Brake Lines) by MaxTrac GroupBuy Nov. 3 - Nov. 11
Discussion in 'Group Buys' started by Gregero, Nov 3, 2011.
Thread Status:
Not open for further replies.
  1. Feb 15, 2012 at 7:35 PM
    #821
    southlandmotoring
    southlandmotoring New Member
    Darren
    Corona, CA
    Sorry all spindles are sold out and waiting on more
  2. Feb 16, 2012 at 8:04 AM
    #822
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
  3. Feb 16, 2012 at 9:16 AM
    #823
    southlandmotoring
    Darren
    Corona, CA
    as far as my Inventory and Maxtrac they are sold out, I am sure there are other retailers that might have a few sets left, I buy direct and not from other retailers, I will have more once more are available, they are saying April sometime.
  4. Feb 16, 2012 at 10:06 AM
    #824
    yamaha73
    yamaha73 Well-Known Member
    Royce
    Madera ranchos
    1997 4runner, 1980 Toyota pickup
    4Runner- wagoneer Dana 44 front lunchbox locker. Rear stock axle spooled. Beadlocks and 36s 3link rear, leaf front, dual transfer cases 1980 pickup- exo cage. Locked front and rear on 40s dual transfer cases. Custom paint job
  5. Feb 17, 2012 at 12:36 PM
    #825
    bradmx421
    bradmx421 Well-Known Member
    Brad
    Riverside, CA
    13 DCLB sport 2wd
    Maxtrac 4" spindles, 1" AAL in the rear,
    ive purchased form darren...great guy, no complaints here...couldnt be happier. click on my profile pics to check out what darren did to my truck
  6. Feb 17, 2012 at 12:49 PM
    #826
    bradmx421
    Brad
    Riverside, CA
    13 DCLB sport 2wd
  7. Mar 19, 2012 at 4:21 AM
    #827
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    Any update on availability with these? Also, I am assuming that the brake lines are necessary with this lift which is why they are offering those also?
  8. Mar 19, 2012 at 4:15 PM
    #828
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    Yeah brake lines will have to b swapped out.
  9. Mar 19, 2012 at 4:58 PM
    #829
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    Would they have to be swapped out with AAL or a leaf pack in the back also?
  10. Mar 19, 2012 at 5:09 PM
    #830
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    If you go above 2", yes.
  11. Mar 19, 2012 at 6:43 PM
    #831
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    Thanks!
  12. Mar 19, 2012 at 6:44 PM
    #832
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    anyone notice that when you turn it feels like there is a pop feeling in the steering wheel? usually when completing a turn? i thought maybe the tie rods
  13. Mar 19, 2012 at 7:52 PM
    #833
    TACWUT
    San Diego
    12 prerunner DC
    Yeah bro, Im pretty sure its the tabs hitting. The tabs that stick out where you connect your lines to the spindles. Look at the other mx spindle thread, sum one covered that on one of the last 4-7 pages.
  14. Mar 19, 2012 at 7:54 PM
    #834
    anthony250f
    Anthony
    San Diego, CA
    so if i trimmed the tabs off it would cure it? it kind of annoying actually.....and i havnt noticed it before...did you ad locktight to the hub bolts?
  15. Mar 19, 2012 at 9:38 PM
    #835
    TACWUT
    San Diego
    12 prerunner DC
    Yeah, if you turn it at full lock, you can c where it would actually hit. I havent trimmed mine cause ive been busy but I try n avoid full lock.
  16. Mar 19, 2012 at 10:04 PM
    #836
    yamaha73
    Royce
    Madera ranchos
    i just noticed this same popping noise also, but i thought i did something wrong at install, so ur saying its the mount for the brake lines?
  17. Mar 19, 2012 at 10:07 PM
    #837
    anthony250f
    Anthony
    San Diego, CA
    im gonna check it out tommaro, i thought i messed up on the install also, where is the tab hitting? the coil?
  18. Mar 19, 2012 at 10:28 PM
    #838
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    The black metal retaining mount that you remove from stock spindle and place on the new spindle that holds the bottom end of the brake line at full lock will hit. It's actually hitting the swaybar. I posted a picture of what I quickly cut to fix the problem. I'll grind it down pretty and spraypaint when I get back from deployment.
  19. Mar 19, 2012 at 10:39 PM
    #839
    TACWUT
    San Diego
    12 prerunner DC
    This is from the other thread titled maxtrac spindles for 2nd gen prerunner its on pg 19 n shows the picture.
  20. Mar 19, 2012 at 10:41 PM
    #840
    TACWUT
    San Diego
    12 prerunner DC
    I forget where it hits but you'll c it when u look.
Thread Status:
