4 time water pump change still Leaky??
Discussion in 'Technical Chat' started by Mondwa, Nov 22, 2010.
  1. Nov 22, 2010 at 8:11 AM
    Mondwa
    Mondwa [OP] Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    Ok guys i am about to push my 89 toyota 4cy off a cliff. I noticed that i was overheating. So i checked all fluids and hoses. fluid low but hose's ok so i replaced thermostate and refilled. Still over heats so i flush radiator and refill. Still overheats. Next i look and notice the water pump is leaking. I pulled off old one and replaced with a remanufactured pump from napa with just gasket. Still leaks so i pull and clean then go with just liqud gasket and put it back together for it to leak instantly. So i pulled and cleaned and then got another gasket and put liquid gasket and the paper gasket on.Wow its not leaking, it last for about a month then i notice i am leaking again. This time it leaks the min i put fluid in it with out it even running. So any ideas? could the radiator be over pressurising the seal around the pumnp and blowing it out? Thanks for any help
  2. Nov 22, 2010 at 8:15 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I think you just got a bad pump. Is it leaking out of the shaft seal?
    This is a 22re correct? When was the the timing chain replaced last? Current mileage?
  3. Nov 22, 2010 at 8:19 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Just a heads up, but I once had just a single grain of sand responsible for a pretty serious oil gasket leak. I would seal fine until it got to operating temperature then it would just pour out oil.
    does your engine have a bypass for the coolant circulation? can't remember the actual name for it. but maybe yours is broken? (If you have one)
  4. Nov 22, 2010 at 8:53 AM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    No its not the shaft or the hole that lets u know the pump is bad. It is where the pump and block meet. Yes its the 22re
    not sure about the bypass but i have cleaned both parts till they look better than factory.
  5. Nov 22, 2010 at 9:04 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    I am willing to bet it's the pump that is bad. I've seen it once before.
  6. Nov 22, 2010 at 9:07 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    Are you making sure you tighten the bolts evenly and to the right torque?
  7. Nov 22, 2010 at 9:08 AM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    Yea that is what i am thinking
    Yep
  8. Nov 23, 2010 at 7:58 AM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    ok so i think 4th time is the charm. I pulled and cleaned and replaced pump for the 4th time and doesnt seem to be leaking but i dont think the -10 weather is helping me out at all. So i will find out later this wk if i got it. Also i think the Radiator is creating a back pressure so i left the lid cracked to see if that helps. Any other ideas?
  9. Nov 24, 2010 at 6:34 AM
    cinch
    Al
    Boulder Creek Ca
    The cooling system is designed to work under pressure (12 PSI I think). If you leave the radiator cap loose the system will not work properly, especially if it's as cold as you say it is.
  10. Nov 24, 2010 at 6:39 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    X2.........the pressure prevents boiling. I thought it was 19 psi?
  11. Nov 24, 2010 at 6:56 AM
    Mondwa
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    yea i understand that it is supposed to have pressure but i thought that it might be creating too much pressure cause something was blocking the flow. But after two days of curring and no fluid i filled it and let it bubble out all the air and it seems to be doing fine but i only drove it for a few mins as it was -10 with out wind chill last night. I will find out today when i drive it. Thanks guys for all the help
