4 Tires & rims or 5 tires & rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_dee151, Mar 25, 2024.
  1. Mar 25, 2024 at 9:12 PM
    TRD_dee151
    TRD_dee151 [OP] Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    I hear the only benefits if you go up to a 17inch tire is something about bigger brakes? Is that all?
  2. Mar 25, 2024 at 9:38 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I always buy 5 wheels and 4 tires. Put one wheel into storage so when you prang a wheel one day you’ll have a replacement and not be stuck with 3 wheels when you realize they stopped making them.
    RIX TUX and TRD_dee151[OP] like this.
  3. Mar 25, 2024 at 9:48 PM
    AK Dudeman
    AK Dudeman Well-Known Member
    DCBLB OR MGM 22
    5 & 5 summer & Winter.. & it’s on PRO wheel…
    Discount Tire and TRD_dee151[OP] like this.
  4. Mar 26, 2024 at 7:37 AM
    TRD_dee151
    Oregon
    im lost cause your rims are NOT impact .....
    Stevie17[QUOTED] likes this.
  5. Mar 26, 2024 at 7:40 AM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Oh , my bad I was gonna get the impact and ended up with the Trail. :eek::D
  6. Mar 26, 2024 at 7:42 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for the recognition! We greatly appreciate it.
  7. Mar 26, 2024 at 8:18 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    No, there's remarkably more tire offerings in a 17" size, I assume because of their commonality across many vehicles. For example, you may only find SL/P rated or E load tires in a specific 16" tire size; that equivalent 17" tire may be offered in SL/P/C/D/E. That may not be important to you, but for some, going up in tire size and having the ability to retain certain load ratings without being forced into an E load is nice. For me, availability is important; I know that I could get a 265 or 285/70/17 in any given shop I visit if needed same day in an emergency, and wouldn't have to order one or go across town searching all day.
  8. Mar 26, 2024 at 8:22 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I do 5. I like doing a 5 wheel rotation. Get more milage out of your tires. And I like having a spare that matches the rest.
    musicisevil and Stevie17 like this.
  9. Mar 26, 2024 at 8:30 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I used to always do 5 matching wheels and tires back in the day and found rotating them and how long they lasted didn’t add up for me.
    With the Tacomas/4Runners I had I would actually buy (4) 265/75-16 tires for the truck and one 235/85-16 for the spare. Tucked up nice underneath and close enough diameter if I ever needed it to limp to a tire repair shop.
  10. Mar 26, 2024 at 9:54 AM
    TRD_dee151
    Oregon
    So question you have 5 tires & 5 aftermarket rims on your truck right now? How dirty does that 5th wheel get? Will it get ruion or stained
  11. Mar 26, 2024 at 1:25 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    you would have to change the TPMS sensor every time
  12. Mar 26, 2024 at 1:32 PM
    RIX TUX
    ^^^this, the last thing i will do is change a tire.....try a plug, air it, limp it home or tire shop.....maybe just maybe use fix a flat
  13. Mar 26, 2024 at 2:00 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    what if your new set up is 0 offset and your spare is the what ever it is (probably +25) if its the same as OEM on the TRD?
  14. Mar 26, 2024 at 2:44 PM
    pca501212
    pca501212 Well-Known Member
    Alex
    Houston
    Wanted to add on to this question - does wheel width matter at all?
    i.e.
    (4) 16x8 aftermarket wheels
    (1) 16x7 spare wheel
    Thanks,
  15. Mar 26, 2024 at 5:29 PM
    #35
    TRD_dee151
    Oregon
    Whats the plug kit about? What exactly are they?
  16. Mar 26, 2024 at 5:35 PM
    #36
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Tire plug kit. Chunk of rubber.
    Can leave tire on truck. Yank out the nail/screw/whatever. Ream hole, plug hole. Add air if you can. Drive as if it never happened.
    Stevie17 likes this.
  17. Mar 26, 2024 at 5:39 PM
    #37
    Stevie17
    Stevie
    Crossville, Alabama
    I have the same rim and tire on my spare that I have on the other 4. :thumbsup:
  18. Mar 26, 2024 at 5:53 PM
    #38
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    5 and 5.
    I bought my wheels used and he had 5 of them. So I have a matching wheel and tire for my spare.
  19. Mar 26, 2024 at 6:02 PM
    #39
    Mark77
    Mark
    Nothing yet
    I do, haven't had any issues.
  20. Mar 26, 2024 at 6:41 PM
    #40
    RIX TUX
    A kit to plug a hole on a tire that can done while on the truck
