4 Tires & rims or 5 tires & rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_dee151, Mar 25, 2024.
  1. Mar 28, 2024 at 4:37 PM
    #61
    908tacoma
    908tacoma Well-Known Member
    New Jersey
    2018 MGM
    OME, SPC, TRD
  2. Mar 29, 2024 at 6:43 AM
    #62
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    You won't be disappointed; it's a quality kit that you can really put some muscle into and not have to worry about bending or breaking it.
    The only downfall is the little tub that the lube comes in doesn't seal well. Once you remove the factory foil seal from it, I would recommend putting some cellophane or something similar on it before putting the lid back on to help keep it from leaking. I learned this lesson the hard way; in the Texas heat, that stuff melted and leaked all over the inside of the case. At least it was contained in the case and didn't get in the cab. I store mine on its side though, if you store it flat it shouldn't be an issue.
    #62
    Stevie17 likes this.
  3. Mar 29, 2024 at 8:22 AM
    #63
    TRD_dee151
    TRD_dee151 [OP] Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    thanks for the Tip, i'll be sure to put it in a ziplock baggy that kit does look very sturdy plus its ARB cant go wrong....
    Stevie17 and TexasTacoLT[QUOTED] like this.
