4 ton or 6 ton jack stands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaliforniaTaco, May 14, 2009.
  1. Dec 9, 2009 at 12:14 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    maybe cause im crazy mountain folk but i just use a chunk of fire wood lol
    tallest jack stands for the win! you can hold up a big rig with 4 ton stands. 4 4ton stands is 32,000 lbs.
  2. Dec 9, 2009 at 12:17 PM
    Yoytoda
    Roland
    completely stock
    well 4 4tonners can hold 32,000lbs and 6 tonners can hold 48,000lbs. not worth arguing. I dont own anything more than 32k lbs. lol
  3. Dec 9, 2009 at 12:42 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
  4. Dec 9, 2009 at 12:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    :eek:
    :anonymous:
  5. Dec 9, 2009 at 12:45 PM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    For jack STANDS read the instructions carefully. Some are rated per pair and so the rated load per stand is half of the amount on the package.
    I bought these Craftsman 21" high lift 3ton jack stands. Thats 3 tons per pair, so 1500lbs each.
    http://c.sears.com/assets/own/00950159e.pdf
  6. Dec 9, 2009 at 12:58 PM
    Yoytoda
    Roland
    completely stock
    Really...
  7. Dec 9, 2009 at 1:34 PM
    SManZ
    Fauquier County, VA
    I got curious about the ProLift 3 ton 21" jack stands I have and looked at the warning labels and manual. Nothing is mentioned about them being rated per pair.
    I called ProLift and they confirmed that the rating is 3 tons for the pair and they are intended to be used in sets. Same with all the rest of their jackstands The load ratings as a pair may be standard practice.
    In reality it shouldn't matter on these trucks unless you're using one jack stand to support one end of the vehicle which you shouldn't be doing anyway. But definitely heads up if any of you are using these on commercial vehicles or anything like that. Also remember that when you're lifting a vehicle you'll almost never be lifing exactly 1/2 of the curb weight. Depending on the vehicle the front can weigh significantly more than the rear or vice versa.
  8. Dec 9, 2009 at 4:10 PM
    Yoytoda
    Roland
    completely stock
    i was just messing with you because 3ton is 6000lbs./2 = 3,000lbs. each lol
