4 wheel alignment on 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01tacoprerunner, Aug 27, 2010.
  1. Aug 27, 2010 at 1:10 PM
    01tacoprerunner
    01tacoprerunner [OP] Lifted 'n Locked 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner with No-slip locker
    4WD Conversion, No-slip locker, 5100s set at 2.5" and shackles in the back. Black 2nd gen rims, and Courser M/T tires, Bull Bar,Fog lights, UWS toolbox, CB Radio, Fiberglass antenna, 2nd Gen Badges, Deck Plate Mod, Diff Breather Mod, Sockmonkey decals.
    Can you do a 4 wheel alignment on a 2001 Toyota Tacoma prerunner??
  2. Aug 27, 2010 at 1:45 PM
    01tacoprerunner
    Brian
    Raleigh, NC
    Help me can you actually do it or should I only be charged for a front alignment? 2001 Tacoma preunner
  3. Aug 27, 2010 at 2:36 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    There's really nothing to align in the rear. Nothing to adjust anyway. The FSM has no specs for the rear either, nor does the alignment procedure say anything about the rear. If the rear is on straight and nothing is bent, thats about it.
  4. Aug 27, 2010 at 9:18 PM
    bivey
    bivey Well-Known Member
    That's corrected can't 4 wheel align a rear wheel drive vehicle
  5. Aug 27, 2010 at 9:27 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I take my truck to the local Sears since they seem to do a pretty good job. The last time I asked for just a front wheel alignment & they said for $60 4 wheel was included anyway.
    I did all the suspension work myself & I did not notice or understand what could be adjusted in the rear. The printout showed the rear toe did come out different than before it went in & they do put thos alignment mirror things on the rear wheel too.
    I came to the conclusion that they do the front wheel alignment somehwat based on the alignment of the rear axle. Otherwise if your rear axle was way out of whack & they just did the front only, maybe the truck might look like it was driving down the street sideways? :laugh:
  6. Aug 27, 2010 at 9:32 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    not true. you can't align the rear suspension of a car with leaf springs in the back. there's nothing to adjust. they're just always "basically" straight unless you really fucked something up.
    there may be some freak exceptions to that rule, but that's how it is with most all vehicles.
  7. Aug 27, 2010 at 9:45 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I think some of those goofball looking mini vans with coil spring rear ends (Honda comes to mind) use 4 wheel alignment for "toe-in" "toe-out" .....:cool:
  8. Aug 27, 2010 at 9:53 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    I agree, it's just vehicles with leafs. For most independent suspension rears there almost always at least toe adjustments. Well on Japanese cars anyway causes that's 90% of the lowering jobs I did at my old work.
  9. Aug 27, 2010 at 9:57 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Independent rear cars can be aligned, we custom aligned my friends SC300 for camber and toe after we dropped it, it's like a 4x4 front suspension, with cv axles and control (trailing) arms.
  10. Aug 28, 2010 at 6:24 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I just had a 4-wheel alignment done at the Toyota dealership on my 03 Prerunner.
  11. Aug 28, 2010 at 11:45 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    They just fed you BS probably to justify their pricing. Like people have said before you cant align the rear end of solid axle with leaf springs, there isn't anything to adjust. They probably just checked it and it was in specs.
  12. Aug 29, 2010 at 7:58 PM
    Yamaha Dave
    Actually I didnt pay for it it was included in a warranty/maintenance program so they had ZERO reasons to feed me any lines because they werent making any money off me. I told them the same thing and they showed me they put the truck on the lift and used I guess lasers and other alignment contraptions that went on all four wheels while I watched. Then they showed me the numbers and how far each wheel was off on the screen.
