4 Wheel Brakes Locked
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaCoyhaique, Aug 23, 2023.
  1. Aug 23, 2023 at 6:11 PM
    TacomaCoyhaique
    TacomaCoyhaique [OP] New Member
    Sergio
    2017 Tacoma TRD PRO
    Hi
    Sorry about my english i will try to do the best.
    I own a 2017 Tacoma TRD PRO
    Some days ago the brakes locked, after releasing the pedal, 4 wheels where still locked. If i release pressure loosing a brake line it will work normal for a couple of minutes. Then it will happen again.
    Thanks for you help
    Sergio
    Coyhaique, Chile
  2. Aug 23, 2023 at 6:19 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I would check all your brake lines to make sure nothing is pinched shut, otherwise its probably something going on with the brake booster/abs system (on the pro its all in one)
  3. Aug 23, 2023 at 6:28 PM
    TacomaCoyhaique
    Sergio
    2017 Tacoma TRD PRO
    We tried with another brake booster, same problem... I will check the lines... but it is weird. 4 wheels are locked.
  4. Aug 23, 2023 at 6:34 PM
    5nahalf
    Erik
    Minnesota
    Normally I would say its a collapsed brake line, but that happens on just the soft lines and usually on just a single wheel. The fact that all the wheels are doing it leads me to think its not a collapsed soft line, but rather a kinked or pinched hard lines.
    OZ TRD likes this.
  5. Aug 23, 2023 at 7:26 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    Trace the path of the brake line, from the brake booster. There shouldn’t be any kind of check valve or restriction because fluid has to flow back to the booster. The only things I can think of that would restrict the flow are the ABS circuit, A-TRAC function or possibly any ‘hill holding’ feature (but that might be a transmission function).
    Try pulling the fuse for the ABS or for A-TRAC. If the problem goes away, you may have an ‘electrical’ related issue. Maybe the ABS modulator. If the problem persists, more likely a mechanical / physical issue.
    I’m not familiar with the TRD Pro, so others might have better advice. But if it takes a few minutes to repeat the failure, that sounds like the truck is trying to do something it shouldn't, like applying the brakes for you.
    Hope this helps with the problem solving. Mucha surete!
