4 wheel drive button
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003 TRD Man, Feb 17, 2010.
  1. Feb 17, 2010 at 7:39 AM
    2003 TRD Man
    2003 TRD Man [OP] Well-Known Member
    Edison N.J.
    03 TRD automatic
    I am fairly new to using 4 wheel drive,except in winter.
    Why does my truck dash icon of 4 wheel drive sometime not come on when engaged?
    Also taking it out also hear at times a popping sound,like popping out of gear?
    Is there fluid I need to be changing?
    Thanks guys, John :confused:
  2. Feb 17, 2010 at 7:44 AM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    sometimes it take a fw seconds for the light to come on. when you hear it pop... are you accelerating? your just forcing the 4wd gear in when you hear the pop....not recommended
  3. Feb 17, 2010 at 7:44 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If the dash light & system is working properly, it should only come on when you're fully engaged in 4WD. If the light isn't on...then you're not in 4WD.
    That popping/clunking is normal when disengaging 4WD.
  4. Feb 17, 2010 at 7:46 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah, theres fluid in your front Diff. and transfer case. That you should change every 30-60K miles or so. It can get pretty thick if its sits for awhile and not using the 4wheel drive often. And I would go with synthetic.
  5. Feb 17, 2010 at 8:15 AM
    2003 TRD Man
    Edison N.J.
    03 TRD automatic
    How much fluid in front diff/transfer case?
    Do you know what weight and brand of syn?
