4 Wheel Drive Concern
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drouse, Dec 16, 2013.
  1. Dec 16, 2013 at 7:54 AM
    Drouse
    Drouse [OP] Well-Known Member
    Dan
    Pittston, PA
    2011 Tacoma DCSB TRD Sport
    Well we got some snow this wkend in NEPA and while out and about was having some slippage so threw it in 4x4. Everything seemed fine up until I arrived at Best Buy and went to park. As I turned the wheel a little more the truck started to jerk. This only happened when making a hard turn (parking - turns on side streets). Is this normal?? I owned a 2004 Taco prior to this and never experienced anything like this while in 4wd. Any ideas??
  2. Dec 16, 2013 at 7:57 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    yup, hopefully you were in 4H? turn it off in the parking lot when your turning hard.
  3. Dec 16, 2013 at 8:08 AM
    Drouse
    Dan
    Pittston, PA
    Ok - As long as it's normal. Yeah I was in 4H. Like I said never experienced this in the 2004 so definitely worried me. Didn't want to hurt anything.
  4. Dec 16, 2013 at 8:13 AM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2016 TRD Off Road 4x4 DC/LB
    3" Toytec lift 16x8 Methods 285/75R16 Toyo Open Country M/Ts
    If you drive on pavement in 4WD and make hard turns it will jerk and bind up. That's normal.
  5. Dec 16, 2013 at 8:22 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I would put it in 2 wheel drive if you need to make sharp turns on pavement. It's not good for the driveline to bind it up like that.
  6. Dec 16, 2013 at 8:23 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Normal
  7. Dec 16, 2013 at 8:25 AM
    Paleus
    Paleus Well-Known Member
    Arkansas
    '13 DCSB TSS 4x4
    Normal, but not good to do a lot.
  8. Dec 16, 2013 at 8:28 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Normal. Welcome to the world of 4WD :) They all do that unless you drove an AWD which has a center differential :)
    DON'T continue to drive on dry pavement in 4WD. You WILL break something.
  9. Dec 16, 2013 at 8:30 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    As I understand it, that's caused by the different turning diameters of the L&R front tires causing the engaged 4wd gearing to bind. This bad.
  10. Dec 16, 2013 at 10:17 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Not true,
    it's caused by the different turning radius of the front versous rear
    ie: the rear tires travel a shorter distance than the front tires in a turn
    in snow its ok to do
    on wet pavement its not good (don't do it)
    on dry pavement its a no no (could over stress parts and break sh*t)
  11. Dec 16, 2013 at 10:38 AM
    OZ-T
    Peter North
    British Columbia
    wut
    If that was the case , why wouldn't the truck bind up every time you turned the wheel in 2WD ?
  12. Dec 16, 2013 at 10:47 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Normal. I take it out of 4 wheel for sharp turns. Also if Im in a hard spot and I want it in 4wd. Ill just do a 3 point turn with micro turns.
  13. Dec 16, 2013 at 10:49 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Because the frontend is under power
  14. Dec 16, 2013 at 10:53 AM
    Paleus
    Arkansas
    '13 DCSB TSS 4x4
    Not just because it is under power, but because there is no differential between the front and rear axles. The front and rear wheels are locked together.
  15. Dec 16, 2013 at 10:54 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    because the diffs are no longer connected through the transfer case which allows them to spin at different speeds in 2wd
  16. Dec 16, 2013 at 10:55 AM
    Paleus
    Arkansas
    '13 DCSB TSS 4x4
    The front and rear axles are not linked in 2WD. They can turn independently.
  17. Dec 16, 2013 at 11:15 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Huh. Never heard it explained this way. It has always been explained as left and right tires having a different turning radius. The above make sense for a sharp (practically locked)turn but on an average turn the radius front to rear is the same and different inside track to outside track. Both situations can cause binding on dry payment and 4H should be removed.
  18. Dec 16, 2013 at 11:18 AM
    SoCaltaco65
    Sigh...
    and
    pavement was more then likely wet...
  19. Dec 16, 2013 at 11:39 AM
    Paleus
    Arkansas
    '13 DCSB TSS 4x4
    Rotational differences on inside track to outside track on the same axle don't matter because there is a differential on both the front and rear axles. The problem arises because there is no differential between front and rear axles when 4x4 is engaged. So the problem is not that left and right wheels on the same axle rotate different amounts or that front and rear wheels on the same side of the truck rotate different amounts (although in tight turns they do), but that front inside and rear outside (or vice-versa) wheels have rotational differences.
  20. Dec 16, 2013 at 11:51 AM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
