4 wheel drive is not engaging?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SurfMama, Aug 21, 2011.
  1. Aug 21, 2011 at 3:47 PM
    SurfMama
    SurfMama [OP] New Member
    Nancy
    Virginia
    Hi, Took my Taco in for a nail in a tire (under warranty)and a brake "idiot" light. Service department at the dealership said my transfer case was leaking. They did repair and now tell me my 4 wheel drive is not engaging. Am I female being taken for a ride $$? I didn't have any problems this past winter with the 4 wheel drive.:confused:
  2. Aug 22, 2011 at 10:12 AM
    96Taco
    96Taco Well-Known Member
    Alberta
    '04 V8 4Runner
    ..stay tuned
    What year is your truck? Is your 4 by engaged using a stick or a push button?
    I had some problems with my 4 by not engaging and/or not disengaging. I switched the vacuum on the VSV a few times and this seemed to free things up. Now works fine. From what you've written it sounds like they were working on the transfer case, messed something up now want to replace it.
    Was the four wheel working before you took it in to the shop?
    I don't trust anyone working on my truck for that reason.
  3. Aug 22, 2011 at 10:20 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    it sounds like they messed it up if it was working before.
    you need to tell them that it worked fine before you took it to them, and now that they worked on it, it doesnt work anymore. tell them they need to fix it free of charge with a free rental car. and if they say no, tell them you will call corporate.
    dont let them f with you just cause your a chick
  4. Aug 22, 2011 at 1:36 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Also tell them you want to see the parts they replaced.
    Had you used the 4WD recently (before you brought it in)? Sounds fishy if it was working before.
    What did they "do" to fix the problem, replace a gasket, tighten a bolt, etc...???
    Brake (idiot) light wouldn't come on with a leaking T-case, at least I can't see why it would...
