4 wheel drive isn't engaging. help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4wheel4fun, Mar 26, 2009.
  1. Mar 26, 2009 at 9:05 PM
    4wheel4fun
    4wheel4fun [OP] New Member
    mira loma, CA
    95 toyota tacoma 3.4L V6 4X4
    okay so my 4 wheel drive isnt working and i cant figure out why. it shifts into 4 low and 4 high and i can feel the difference in the gearing and everything (its a manual transfer case if u wanna know) but the front tires arent spinning. my friend mentioned that some trucks use vaccum to engage it so i checked it out at school in auto and i do have what looks like to be some sort of vaccum mechanism. it looks like a diaphragm and two vaccum hoses but neither hoses lead to the engine so i dont know how this is supposed to work. if anyone has a clue of whats wrong, then please help me. my teacher said the diaphragm could possibly be torn but i dont wanna take it apart and find out its not. i'm just wondering if anyone else has had the same problem.
  2. Mar 27, 2009 at 2:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Go here: And download the FSM for your year. :)
  3. Mar 27, 2009 at 2:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    And Welcome to TW! :)
  4. Dec 29, 2011 at 7:33 PM
    02tacomabarrie
    02tacomabarrie Member
    Dan
    ontario Canada
    02 double cab supercharged
    3 in lift,super charged,goodyear teritories
    has anyone changed the actuator switch on transfer case
  5. Dec 29, 2011 at 7:37 PM
    02tacomabarrie
    Dan
    ontario Canada
    im having problems with the 4x4 working properly its not engaging with the button
  6. Dec 29, 2011 at 8:26 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    Op. I had problem with my 4x4 not working too. Does your four wheel green light in the dash light up? If so, it's probably working. That light that comes on is "real" as the sensor only activates if it's engaged. The four wheel is vacuum actuated and u can find the 2 vsv's in the driver side panel by the battery and evap system. Just follow the vac lines from the actuator and up. Slip the hoses off and reverse them. Engage and disengage the four wheel. Swap hoses back. This is free and takes 5 minutes
  7. Dec 29, 2011 at 8:34 PM
    TACO99
    TACO99 Well-Known Member
    Caleb
    sevierville tn
    2003 tacoma extra cab 3.4l v6 4wd sr5 trd
    2" spacer lift 2" body lift. 33/11.50/18 nitro trail grapplers on 18x9 fuel wheels. Camo interior after market smoked led headlights. Homemade push bar 2 10" LEDs bars.
    i had the same problem with m 86 4wd truck turns out it was the lock out hubs had went bad
  8. Dec 30, 2011 at 4:53 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    Are the hubs manual on your truck? Are you in neutral when you shift from 2WD to 4HI? You don't have to be in neutral, I think you can select 4HI below 25mph? Maybe even faster, it's in your owners manual. Try Selecting 4WD at different speeds and in neutral. How do you know the front wheels aren't spinning? Unless you've stuck the truck in 2WD and selecting 4WD doesn't help, how can you be sure? As 96Taco mentions, if the green dash indicator is on and you're not getting power in front, that could be a whole other set of issues.
  9. Dec 30, 2011 at 5:56 PM
    02tacomabarrie
    Dan
    ontario Canada
    i have actuator problems i took it apart and now cant put it together right so it works properly ****** up dont know the defualt mode to start
