4 wheel drive light flashing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justin marois, Feb 19, 2023.
  1. Feb 19, 2023 at 1:50 PM
    Justin marois
    Justin marois [OP] New Member
    Justin
    Tacoma 2010
  2. Feb 19, 2023 at 2:03 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Since all your ADD voltages (Dl1, DL2, & ADD) are 0v I'd start with unplugging the ADD on the front axle and make sure they all go to 12v, if they do then your problem is in the ADD actuator.
    TnShooter likes this.
  3. Feb 19, 2023 at 5:13 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Looks like TL2 limit is not closing on the transfer case.
  4. Feb 19, 2023 at 5:18 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's not allowing any shifts because all the limits on the ADD are at 0v which is out of range.
  5. Feb 19, 2023 at 5:21 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Yeah maybe a short or bad ground on that sub harness.
    Dm93 likes this.
  6. Feb 19, 2023 at 5:25 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If the ground was bad they would all be at 12v or so, since they are all 0v there's ether a short in the ADD or wiring. That's why I said to unplug the ADD and make sure they all go to 12v, if they do it's in the ADD if they don't it's in the wiring.
    6 gearT444E[QUOTED] likes this.
  7. Feb 19, 2023 at 5:25 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    My first thing to do would be unplug at the ADD connector as suggested and check for 12v at the connector. You can go a step further and measure each limit switch to the coming ground on the ADD if you think that helps but the way the system grounds the limit switches it’s not really possible for two to be closed at the same time.
