4 wheel drive light is blinking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Camtaz, Jan 8, 2016.
  1. Jan 8, 2016 at 11:17 PM
    Camtaz
    Camtaz [OP] Member
    2007 Tacoma 4.0 4 wheel drive
    None
    i have a 07 Tacoma and the 4 wheel drive light is blinking. And won't shut off. It was in 4 wheel drive and blinking. I was able to get it to unlock but still blinking
  2. Jan 8, 2016 at 11:20 PM
    Camtaz
    Camtaz [OP] Member
    None
    What's the add and is there a fix for it.
  3. Jan 8, 2016 at 11:23 PM
    Camtaz
    Camtaz [OP] Member
    None
    Could really use some good advice
  4. Jan 8, 2016 at 11:51 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    This is fairly common if it's not used regularly from what I believe....
    Are you in neutral? Try going back into 4wd and moving forward a few inches at a time, stop, back into neutral and retry.
  5. Jan 8, 2016 at 11:55 PM
    Camtaz
    Camtaz [OP] Member
    None
    I have tried everything nothing seems to work. I will check the add. Is there a vacumme line that goes to the add.
