4-Wheel Drive light Stuck on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma.n.Yamaha, Aug 26, 2014.
  1. Aug 26, 2014 at 9:59 AM
    Tacoma.n.Yamaha
    Tacoma.n.Yamaha [OP] Active Member
    Washington
    2007 Tacoma SR5 V6
    Last winter I was driving on the icey and snowey roads of the pacific Northwest and I needed to put my truck in four-wheel drive and so I did so stopped at a light like you are supposed to. Well then I got home and took the truck out of four wheel drive yet the light stays on. It has been on ever since then even though the truck is in 2-wheel drive and the auto-locking hubs disengage. I tried to research and see if others have had this problem but from what I have found it seems like no one has, though they have had problems with a blinking light. 4-Wheel drive still works and I can take it in and out of 4-wheel no problem. So my question is, does anyone have recommendations on things I should check or know what the problem is?
    tacotecno likes this.
  2. Aug 26, 2014 at 12:41 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    im not sure man, when I got my truck the 4wd stopped working (wouldnt engage) . So I bought an A.D.D and the 4x4 switch. All i needed to repair was the A.D.D. I still have the 4x4 switch (in the for sale section) if thats what you need. Brand new.
    Good luck man, hopefully its something simple
  3. Aug 26, 2014 at 2:22 PM
    Tacoma.n.Yamaha
    Washington
    2007 Tacoma SR5 V6
    Thanks man. I might have to look in to it. Like I said it doesn't seem to be acting up or doing anything crazy. Plus I can't find any information on it.
    Must be gremlins....
    J.A.92 likes this.
  4. Aug 28, 2014 at 8:12 AM
    Tacoma.n.Yamaha
    Washington
    2007 Tacoma SR5 V6
    Alright, so update if anyone is having this problem as well (hope not). I checked wires and everything seemed fine. No fuses are out. I am going to trace wires and look for grounds and make sure they all seem good. My next ideas are that the hubs may not be disengaging all the way. When I switch it from 2 to 4-wheel drive I can hear the motor in the front humming but that may not mean much. So I might try to change the front fluid as well.
    I'll keep this thread posted. Being a student and full time worker makes it difficult to find time though.
  5. Aug 28, 2014 at 8:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    Have you tried to see if it actually IS in 4 wheel drive mode still, or just an actuator issue? When you turn in tight corners does it bind up, or turn normally? If it binds up, then you are still fully in 4wd. If it turns normally, then you probably have a front actuator not releasing. As long as the front actuator is engaged, the 4wd light will remain on, because that is the input for the 4wd light indicator.
    cruxofthebisquit likes this.
  6. Aug 28, 2014 at 9:45 AM
    Tacoma.n.Yamaha
    Washington
    2007 Tacoma SR5 V6
    It doesn't bind up and is out of 4-wheel drive. Thanks for the input man. So I will probably start with that. How would I test the front actuator?
    Edit: Alright so I found a test for the front actuator so I will give that a go tonight. Thank you very much, I actually have a lead!
  7. Aug 28, 2014 at 9:45 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Just wordage, but technically you have an ADD (Automatic disconnecting differential) and not auto locking hubs. Both allow shift-on-the-fly into 4WD-HI, but the auto locking hubs require you to drive in reverse to unlock them when you go back to 2WD.
    The ADD 'unlocks' the one side of the front differential to create free wheeling, and does not require going in reverse to unlock.
  8. Aug 28, 2014 at 10:52 AM
    Tacoma.n.Yamaha
    Washington
    2007 Tacoma SR5 V6
    Alright. I apologize. I appreciate all this you guys. I am pretty new to this so I am glad that you guys are bearing with me as it may be slightly painful to read. But all this help is awesome. Loving the forum and also a huge fan of all the users.
    otis24 likes this.
  9. Aug 29, 2014 at 5:35 PM
    David K
    Glad you are here to help have fun in our Tacomas!
  10. Feb 18, 2016 at 9:35 AM
    tacotecno
    tacotecno New Member
    Canada
    2002 4x4 double cab tacoma
    None
    My 2002 have same problem 4-wheel light stock on.I know 4x4 H and L working fine since i drive in snow all time so i decided to ignore the light for now . Wish you good luck solving problem
  11. Mar 23, 2018 at 3:18 PM
    Brine=Z
    Brine=Z New Member
    1997 Tacoma 3.4L 4x4
    Does anyone have an answer for this? 4x4 light on dash staying on, even in 2wd... Came on while in 2wd driving down the road... 4wd is working perfectly... (1997 3.4l)
  12. Nov 16, 2018 at 8:56 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Saw the same behavior last night.. first snow so side streets were good to give 4wd a workout.
    approaching main street and it was clear so switched from 4hi to 2hi and light stayed on
    eventually just pulled over and shut off and restarted and light went off.
  13. Jan 19, 2019 at 8:37 PM
    Dreadmyst
    Dreadmyst Active Member
    Colorado
    2004 White Tacoma DLX TRD
    I just bought a 2004 tacoma and i have encounter this exact issue. has anyone actually found a fix for this? Is it the actuator that was mentioned above and if so how hard are they to fix/replace?
