4-Wheel Drive Not Engaging
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bmans97Taco, Jul 19, 2025.
  1. Jul 19, 2025 at 11:08 AM
    Bmans97Taco
    Bmans97Taco [OP] Active Member
    Brian
    1997 Tacoma 4x4
    Stock
    The 4-Wheel Drive on my 1997 Tacoma 2.7 Liter is not engaging. It is a 5-speed manual with a physical stick lever that engages the 4x4. (It is not an electric push button engager). When I pull the lever into 4 Hi or 4 Lo nothing happens (the green 4x4 indicator light on the gauge cluster does not illuminate either). I checked the 4x4 fuse in the cabin and it appears to be good). I jacked the truck up on stands so all four wheels could freely spin and while idling the engine in first gear I engaged the 4x4, but only the rear wheels moved. While 4-wheel drive was engaged I could see that the short drive shaft from the transfer case to the front differential was spinning, but neither front half shaft axles from the output of the front differential to the front wheels moved. So, the problem appears to be isolated to the front differential. Is this perhaps an actuator in the front differential? Let me know where you think I should start troubleshooting from here.
  2. Jul 19, 2025 at 11:22 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It more than likely the actuator on the front differential.
    Not always, but usually.
  3. Jul 19, 2025 at 12:50 PM
    RDon
    RDon Member
    KC
    2002 Tacoma Reg 2.7 5sp
    I thought the early models didn't have an actuator. Are your hubs unlocked?
  4. Jul 19, 2025 at 2:31 PM
    Bmans97Taco
    Brian
    1997 Tacoma 4x4
    Stock
    The truck has auto-locking front hubs.
  5. Jul 20, 2025 at 6:29 AM
    RDon
    RDon Member
    KC
    Is the vacuum tube going to the actuator still intact?
