4 wheel drive on a 98 tacoma with locking hubs
Discussion in '1st Gen. Tacomas (1995-2004)' started by tenn, Jan 24, 2012.
  1. Jan 24, 2012 at 6:38 PM
    tenn
    tenn [OP] Active Member
    98 Tacoma 4x4 v6 auto trans.
    i have a 98 tacoma 4x4 with manual locking front hubs. i want to know if the truck "pulls" with all four wheels when the 4 wheel drive is on. or how many wheels pull.
  2. Jan 24, 2012 at 8:27 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    If you have 4wd engaged, but the manual hubs are free (not locked in) then you are only pulling with the back wheels. You must engage 4wd and lock in the hubs in order to pull with all 4 wheels.
  3. Jan 25, 2012 at 5:56 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    There is no such thing as an out of the box 4 wheel drive Tacoma, the basic 4x4 pulls with just 2 wheels when 4 wheel drive is engaged and a Tacoma with the rear locker pulls with just 3 wheels. You need to install a locker in the front for both front wheels to pull when the hubs are locked and the transfer case is in 4hi or 4lo.
  4. Jan 25, 2012 at 1:23 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Nuh uhhhh....
    A-FUCKING TRAC!
  5. Jan 25, 2012 at 4:41 PM
    tenn
    so on a 98 tacoma with locking front hubs, will the truck pull with 4 ?
  6. Jan 25, 2012 at 4:42 PM
    tenn
    so it can pull with 4
  7. Jan 25, 2012 at 4:52 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    on flat ground with traction to all four wheels yes. with open differentials the diff will send power to the wheel with the least traction. meaning if somehow 2 of the wheels one front one rear were off the ground only 2 would spin because of open differentials. with a locker in the rear the rear 2 wheels pull with the front wheel with least amount of traction
  8. Jan 25, 2012 at 5:38 PM
    tenn
    sorry for being dense. but even tho there are manual locking hubs in the front it still has a open diff and will only pull with 1 in the front? i thought if you had to manually lock them in then it would pull with both front tires at the same rate. it seems like it does bc trying to turn with it in 4x4 is a pain. wouldnt that mean that they were not working independantly from one another?
  9. Jan 25, 2012 at 5:41 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Probaby hard to turn with the hubs locked and on dry concrete.
  10. Jan 25, 2012 at 5:44 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Yes an open diff will only pull with 1 tire (the one with least traction). If your driving on flat ground it will be pulling with both but once you get in some uneven terrain the one with least resistance will pull.
    And DO NOT drive in 4x4, on a hard dry surface (pavement)
  11. Jan 25, 2012 at 5:46 PM
    tenn
    but will the tires always rotate at the same speed like in a locking diff?
  12. Jan 25, 2012 at 5:50 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Guessing your trying to turn on pavement? If that is the case, then both tires have full traction and steering will be very stiff. Since both tires turn and are traveling close to the same speed, they are fighting each other within the differential as to where to send the power until one tire has less traction. Don't use 4x4 on pavement.
  13. Jan 25, 2012 at 5:50 PM
    Max-4_Yota
    Michael
    South Carolina
    Squattin'
    yes, no matter how uneven the terrain is with a locked diff both wheels will spin at the same rate.
  14. Jan 25, 2012 at 5:52 PM
    tenn
    let me know if this is right. open- means tires spin independantly so on flat ground power is distributed equally. on uneven ground one with least traction gets more power and therefore will spin and the one with contact will get no power and you will still be stuck. with locking- tires always spin at same speed, so if one tire is off the ground and one is not, the one in contact will still pull and bc they spin equally the one off the ground should only spin at the same rate as the other on
  15. Jan 25, 2012 at 5:54 PM
    tenn
    ok. do all manual locking hubs have locking diff?
  16. Jan 25, 2012 at 5:54 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    For all intents and purposes, that is correct.
  17. Jan 25, 2012 at 5:56 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The hub just connects the axle to the wheel. By unlocking the hub the wheels are able to spin freely from the rest of the drive train. Since in 2wd there is no reason to be turning the rest of the 4wd drive train, you will get better mileage and less wear and tear.
  18. Jan 25, 2012 at 5:58 PM
    tenn
    so my particular truck has locking diff and will better pull me out of mud/snow? as long as the hubs are locked in and 4x4 is engaged with the gearshift
  19. Jan 25, 2012 at 5:59 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You have a factory rear locker?
  20. Jan 25, 2012 at 6:00 PM
    tenn
    yes. as far as i know. i havent had it long.
