4 wheel drive preventive maintenance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greyhound, May 20, 2011.
  1. May 20, 2011 at 7:06 AM
    greyhound
    greyhound [OP] Member
    Mass.
    2011 V6 4X4 SR5
    Owner's manual says that once a month operate in 4WD for 10 miles to lubricate the front drive components. However, only supposed to utilize 4WD while on a "slippery surface" to avoid potential stressing the drive line since front and rear axles turn at the same rate and any cornering on a hard dry surface will create stress.
    So, without any convenient slippery surfaces, I guess we are we supposed to get on a long straight stretch of interstate to accomplish this, right??
  2. May 20, 2011 at 7:22 AM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    You don't need interstate, just 10 miles without any sharp turns. A slow, gradual curve in a road would be fine, or even just a few shorter sections of road and take it out of 4hi in between. Basically just something to get the oil coating the inners.
  3. May 20, 2011 at 7:28 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    there's no dirt roads around ?? Don't operate the 4x4 on pavement, it's not designed for that.
  4. May 20, 2011 at 7:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Actually more the 10 miles you need to turn switch on and OFF. so even if you have 100 FT dirt road piece. Just use that.
  5. May 20, 2011 at 7:35 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    I see no problem with driving on pavement in 4wd drive, just dont do any sharp turns, dont get to heavy on either peddle and your fine. The front and rear axles are geared the same so as long as you not turning to sharp thier wont be an issue.
    I do this every month if I havnt done any trail rides in 4WD.
  6. May 20, 2011 at 7:43 AM
    Project.paradigm
    Project.paradigm Well-Known Member
    Oil Country,Alberta, Canada
    04 TRD 4X4 Dub cab
    Airlift rear air bags. Hood struts. sockmonkey bedside decal. TRD supercharger(not installed). Deckplate. Grey wire mod. Extended rear diff breather. 6000k HIDS. 18"Magnaflow. Truxxx 3" level kit. (Temporary) Wet Okole seat covers. BoxRocket bed rack. Bora 0.75 wheel spacers All pro sliders. BAMF BPV. B&M trans cooler.
    Every couple weeks i engage 4hi. Only while on a long stretch road. If a curve comes up i'll turn it off. If all 4 wheels are going the same speed it shouldn't put any strain on the components.
  7. May 20, 2011 at 7:56 AM
    magnum922
    magnum922 Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    I asked my dealer machanic the same question. He said it woulnt hurt anything if you dont do the monthly 10 miles in 4 hi. Just use it when ever you need it. It will be fine.
  8. May 20, 2011 at 7:57 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Maybe if you had a locker, with open diffs it wont bind.
  9. May 20, 2011 at 8:12 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    But with having open diffs any front to rear binding would be negligible because it would be lost/made up with the slip allowed side to side.
    That is assuming it is minimal binding, if your doing figure 8s and donuts then you will have problems.
  10. May 20, 2011 at 8:19 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    You can always do it on straight roads during rainy periods...
  11. May 20, 2011 at 8:26 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Or have some fun and go on a trail ride.
  12. May 20, 2011 at 8:52 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    If putting you truck in 4wd is a problem for you, then maybe you shouldn't have bought a 4wd? Just my .02
  13. May 20, 2011 at 9:01 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What
    My .02
  14. May 20, 2011 at 9:12 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    I do the same.
  15. May 20, 2011 at 9:13 AM
    OZ-T
    Peter North
    British Columbia
    From now on I'm saying " My tuppence worth "
    Lol , thanks Anthony
    :thumbsup:
  16. May 20, 2011 at 10:47 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Did you just watch Mary Poppins or something?
  17. May 20, 2011 at 8:24 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    A spoon full of sugar helps the medicine go down... and
    Super cala fragi litpus (or something like that)! lol
