4 Wheel Drive Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by big_jarv, Jul 23, 2016.
  1. Jul 23, 2016 at 10:23 PM
    big_jarv
    big_jarv [OP] Well-Known Member
    2020 TRD Pro
    So I was reading my owners manual and it mentions that we should drive at least 10 miles in 4 wheel drive mode a month to ensure proper lubrication of the parts.
    However right under that there is a warning about driving on dry hard surfaces causing damage.
    Is it okay to do the 10 mile as long as I'm driving straight and not making turns.
    Also side note is it okay to turn while in 4 wheel drive while off roading as long as it isn't sudden?
  2. Jul 23, 2016 at 10:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I wouldn't worry about not getting in that quota each month. That's more for someone that has never engaged 4WD and decides to do so after 10 years and is mad when something doesn't work. It's more to cover their ass.
    When it comes to driving on asphalt, I wouldn't recommend it. You could drive it in a straight line and you probably would be fine, but I wouldn't. At the very least, wait until it's raining to do it.
  3. Jul 23, 2016 at 10:38 PM
    big_jarv
    2020 TRD Pro
    Thanks for the response.
    Just curious what difference does it have dry vs wet?
    Is it okay to activate on dirt??
  4. Jul 23, 2016 at 10:43 PM
    Pigpen
    Dan
    Northwest Montana
    Fine on dirt. Asphalt won't wreck the truck if you shift in and out a couple times. It'll be easier on all the parts if you're going straight. The whole point is to fling some oil around the clamshell and exercise the t case and ADD.
  5. Jul 23, 2016 at 10:44 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^I think the oil flings around in front diff clamshell in 2H, since the CV shafts are turning. The front driveshaft U-joints are probably the only components not exercised in 2H.
    If all your tires are at the same tread depth and inflated to the same rolling diameter, driving straight in 4WD is fine on pavement. Large-radius turns (like highway off-ramps) are OK as well. Sharp turns (like pulling into a driveway or parking spot) will cause binding, which will be evident in the steering.
  6. Jul 23, 2016 at 10:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    As mentioned above I just wait for it to rain and the engage it for a few miles and its always been good to go.
  7. Jul 23, 2016 at 10:50 PM
    big_jarv
    2020 TRD Pro
    I live it CA we get rain once a year if that lol.
  8. Jul 23, 2016 at 10:50 PM
    big_jarv
    2020 TRD Pro
    Thank you guys!
  9. Jul 23, 2016 at 10:53 PM
    shakerhood
    Southern Ohio
    Dirt works fine too, you just want less traction for the front wheels.
    big_jarv[QUOTED][OP] likes this.
  10. Jul 23, 2016 at 10:57 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    As opposed to driving off a cliff for the sake of driving straight ??? Yes , please feel free to turn in either left or right hand direction.....
    :confused::confused::notsure:
  11. Jul 23, 2016 at 11:01 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The point is that theres less traction while wet. Like stated above, it's so there's less traction so the wheel can slip and it prevents binding. On dirt, I just drive it totally normal and there's no binding
  12. Jul 23, 2016 at 11:15 PM
    KILLINTIME
    KILLINTIME Like a Villain
    Fwiw, just bought a o6 with 32k miles never seen 4wd or dirt. Previous 80+ year old single
    owner of truck said its 4wd?? 1200 miles a year is bullshit. If you think otherwise I have ocean front property in Kansas That I
    Will sell you On the cheap.
  13. Jul 23, 2016 at 11:33 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    The front axle is not geared differently...the vehicle could travel indefinitely in a straight line on pavement in four wheel drive with absolutely no consequences. All four wheels are travelling the same distance.
    KILLINTIME likes this.
  14. Jul 23, 2016 at 11:52 PM
    eon_blue
    Azusa, CA
    Alright...I must have misunderstood the concept but thanks for editing your original post. I'll delete mine so as not to spread misinformation.
