4 wheel drive stuck in L4
Discussion in 'New Members' started by LEL, Mar 25, 2014.
  1. Mar 25, 2014 at 6:18 AM
    LEL
    LEL [OP] Member
    Larry
    Birmingham, Alabama
    06 Pre Runner
    Good morning to all:
    My name is Larry from Birmingham, Alabama and this is my first ever posting, not sure I am doing this correctly, but here goes: My 2006 Tacoma has recently been difficult to move back into H2 after switching into L4. Not sure what could be causing this malfunction other than the switch itself. I did the normal movement in reverse and back forward several times, but system continued to remain in L4, but did finally release. Switch would move from L4 to H4 to H2 but warning on the dash continued to show L4. Any suggestion, advise will be greatly appreciated...Thanks for reading..
  2. Mar 25, 2014 at 6:22 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Hate to ask the obvious but your switching in and out of 4Lo in neutral?
  3. Mar 25, 2014 at 6:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    This ^^^^ and try doing it with both the engine running, and with just the key on.
    Also, I know this may seem like a dumb question: Is it MECHANICALLY sticking in 4 low? Or is just the INDICATOR saying you are in 4 low, but your transfer case is actually in 2 high/4 high.
    What part of Birmingham are you in? I may be able to come up and see if I can figure it out if it is stuck in 4 low, and you can't get it out.
  4. Mar 25, 2014 at 6:28 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    This and make sure you are at a compete stop while doing so
  5. Mar 25, 2014 at 7:57 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    welcome. step by step on the instructions of the visor.
    also, if you have a 4wd, why the prerunner tag on your truck info?
  6. Mar 26, 2014 at 5:36 AM
    LEL
    LEL [OP] Member
    Larry
    Birmingham, Alabama
    06 Pre Runner
    Thanks to all of you, I am certain I have followed the normal procedures, neutral, vehicle stopped etc, but will try all given suggestions again Your quick response has been greatly appreciated. Larry in Birmingham, Alabama
  7. Mar 26, 2014 at 5:37 AM
    LEL
    LEL [OP] Member
    Larry
    Birmingham, Alabama
    06 Pre Runner
  8. Mar 26, 2014 at 5:38 AM
    LEL
    LEL [OP] Member
    Larry
    Birmingham, Alabama
    06 Pre Runner
  9. Mar 26, 2014 at 5:39 AM
    LEL
    LEL [OP] Member
    Larry
    Birmingham, Alabama
    06 Pre Runner
