4-wheel Drive Will Not Engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlanders, Feb 7, 2014.
  1. Feb 7, 2014 at 7:10 AM
    jlanders
    jlanders [OP] Member
    Jamie
    Abilene, TX
    14 Tacoma TRD Off-Road
    Hey Guys!
    My Girlfriend has an 07 FJ, and I understand her running gear is basically the same as my 14 Tacoma, is that right?
    Her FJ has been babied, typical mom car... This round of snow however I noticed that when I put hers in 4x4 nothing happens... No lights, no nada... Drives just fine, but does not engage the 4x4. No odd sounds, no odd anything other than it's not engaging.
    If you switch to 4L, still no sounds, gearing is low, but no pull from the front.
    Any ideas???
  2. Feb 7, 2014 at 8:05 AM
    braik
    braik Well-Known Member
    Louisville, KY
    2006 4.0L 4x4 BASE
    2" Ironman 4x4 (B) Front Spacer Level LR UCAs Level 8: Tracker Wheels 255/75 Cooper ATPs Welded Rock Sliders Weathertech floormats Wet Okole seat covers JVC Head Unit Diff Breather Mod Zip Tie Mod Needle Bearing Mod HID Retrofit (Acura TL-R)
    When you say no lights, do you mean no warning lights? Or that the 4x4 light doesn't come on at all? If it does come on, does it blink? Is it steady?
    Use the search function on the site and do some reading. Don't be afraid to use different wording. You'll probably find your answer in an hour or so and learn something else in the mean time too!
  3. Feb 7, 2014 at 8:21 AM
    Bhwang
    Bhwang Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    Front ADD maybe, sounds like TC gears are engaging but front actuator is not.
  4. Feb 7, 2014 at 8:23 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Front actuator for sure.
  5. Feb 7, 2014 at 8:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  6. Feb 8, 2014 at 9:25 AM
    jlanders
    Jamie
    Abilene, TX
    You guys rock! That was the issue!
