4 wheel drive won't engage and/disengage - new Tacoma!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Derlenbusch, Jan 31, 2013.
  1. Jan 31, 2013 at 6:03 PM
    Derlenbusch
    Derlenbusch [OP] Member
    Daniel
    Colorado springs, CO
    Tacoma- Trd off road
    3" lift, 33" tires.
    Hi, I bought a new 2012 Tacoma in July. Two months ago my 4 wheel drive will not engage 100% of the time. At least once a day I can try to engage it and the light will just blink and it won't kick in. Then, I can shut it off and it will kick in, then I can't get it out of 4 wheel....
    I have been tot the colorado Springs Larry H Miller dealership 6 times now. Fist they said nothin was wrong, I drove hone ten minutes later and I could not engage it again... I took it back they said the actuator plug was loose. The plugged it back in and said it was fixe. I drove home again and ten minutes later, I could not engage 4 wheel drive! I took it back, they switched out one actuator, drove home same thing. Now they are asking me if I was turning - no, I have owned two differtn Tacoma 4x4 for 13 years, one 2001 and the other a 2009, I never had this happen in either other one.
    So, I take it back now they said the whole plug was hanging there.... I didn't do it, they plugged it back in and on my way home, same thing...
    Three more times back tot the dealership, they say it works fine, I even showed them the light just blinking and not engaging.
    Now I test drove Witt the local Toyota rep. I showed him the blocking light Nd that it would not e gnge, then he drove and could not make it happen for another 2 more hours.
    Their answer is that I am trying to engage on dry pavement. That it crazy, I should be able to Knicks it in on dry payment, or patchy snowy wet roads any time. At least testing, I should be able to test it on dry payment?...
    Any ideas? Thoughts? I think I have a lemon....
    Dan.
    Ps I have daily videos of it not working and they still can't find anything wrong.
  2. Jan 31, 2013 at 6:16 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    If it's new... it is up to them to make it work... sounds like dealer fail to me... Is there another dealer you can use? Call the Toyota Corp. regional rep and ask what you should do. Your salesman should be on your side and help you get the service manager to get it right.
  3. Jan 31, 2013 at 6:57 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    You should be able to engage it any time you want. Dry pavement or not (whether or not recommended...)
    I'd call toyota corporate. Or at least talk to the sales staff.
  4. Jan 31, 2013 at 9:27 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    . . . . . . . on dry pavement, running strait, it could be possible that your gears are lined up just wrong and keeping you from engaging until you turn or something otherwise happens to help line them up.
    with that far cry out of the way, i would be focusing really hard on that plug. twice it was found loose/ disconnected?? somethings wrong
  5. Feb 1, 2013 at 8:10 PM
    David K
    Three 4WD Tacomas, over 1/4 million miles between them, and 4WD has always worked. Occasional engaging while driving straight does no harm... AWD cars have a center diff. so there is no binding while turning... driving straight there is no differential needed. The 4WD will not always pop in instantly, but just let up on the gas a tad, and "thunk" it pops in. If you are trying to go into 4WD while parked, then no... it may not go in until you begin to roll the tires.
  6. Feb 2, 2013 at 12:03 PM
    Derlenbusch
    Daniel
    3" lift, 33" tires.
    Yes, I am going to a other dealer. Thanks.
  7. Feb 2, 2013 at 12:19 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  8. Feb 2, 2013 at 12:38 PM
    Derlenbusch
    Daniel
    3" lift, 33" tires.
    This is my third Trd Tacoma, I am confident that I am doing it correctly. No turns, under 40 and I wait 2 minutes... Not much else to do.
  9. Feb 2, 2013 at 12:49 PM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    SOunds like something was not plugged in during assembly of the truck (Transfer case actuator, Front ADD actuator). Any one of those will not engage 4wd on the truck
  10. Feb 2, 2013 at 12:52 PM
    OZ-T
    Peter North
    British Columbia
    He says it sporatically doesn't engage , those wouldn't allow it to engage ever , no ?
  11. Feb 2, 2013 at 2:52 PM
    92dlxman
    Kevin
    Visalia, CA
    i love how these electronic 4wd systems were made for convenience yet i had less trouble getting my old pickup to go in. lock hubs, hold gentle pressure on the stick till it locks in. those were the good ol days
  12. Feb 3, 2013 at 9:05 AM
    Derlenbusch
    Daniel
    3" lift, 33" tires.
    If it doesn't matter if I am turning or my speed, then what am I doing wrong that the light won't even turn on when I try to engage it????
    This is a brand new truck, it should work.
  13. Feb 11, 2013 at 12:55 PM
    Derlenbusch
    Daniel
    3" lift, 33" tires.
    Okay today, 3" of snow, wet roads. The 4x4 will engage buy the light does not stop blinking. Then, I can't disengage the 4 wheel drive. What a piece of shit!!!!!!!!!!!!
    Rake it back to Toyota and they still can't find anything wrong. They want me to trade it in and take $6k hit! That is bull shit
  14. Feb 11, 2013 at 12:58 PM
    OZ-T
    Peter North
    British Columbia
    You are just trying to shift 2H - 4H and back to 2H , correct ?
    No 4LO involved ?
  15. Feb 11, 2013 at 12:59 PM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    Do you let off the gas, switch into 4wd, then go back on the gas? This always makes it engage for me.
  16. Feb 11, 2013 at 1:07 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    it sounds like OP is trying to go into 4-lo lol
  17. Feb 11, 2013 at 1:55 PM
    OZ-T
    Peter North
    British Columbia
    That's why I asked
  18. Feb 11, 2013 at 4:36 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I drive down the road wet,dry,snow, 60 MPH turn the switch goes into 4X4 H every time. Does not matter if I'm on a curve going up a hill just clicks in. 4 low can be stubborn some times but no issues with high range.
  19. Feb 11, 2013 at 4:59 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I agree. I miss the lever 4WD from my 95 Toyota Pickup. Grab the shifter, throw in 4WD, no questions asked.
  20. Feb 11, 2013 at 8:20 PM
    Derlenbusch
    Daniel
    3" lift, 33" tires.
    Yes correct
