4 wheel drive won't engage
Discussion in '1st Gen. Tacomas (1995-2004)' started by Longley1974, May 15, 2012.
  1. May 15, 2012 at 2:25 PM
    Longley1974
    Longley1974 [OP] New Member
    Wade
    Abilene, TX
    Tacoma 4x4, FJ40
    1997 Taco 4 wheel drive won't engage. The drive shaft turns when in H4 and L4 but there in no power getting to the front wheels. It has a vaccume accuator with two short pieces of rubber hose that "seemed" fine. I couldn't really tell because of all the grease and loom. Any ideas? If it is the accuator where can I get a new one? The local auto parts store was a no go. Thanks for any help.
  2. Feb 4, 2014 at 3:57 PM
    nvchris
    nvchris Member
    Sage Country Nevada
    Tacoma
    I'm having the same problem.
    Trying to find a "how to guide" on how to track down the problem.
    Vacuum leak or ADD or ?
  3. Feb 4, 2014 at 4:37 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    On my 89 toyota pickup I had the same issue. There was a small vacuum solenoid on the passenger side fender that could be bypassed. I did that for a while to get 4wd, then replaced it. I'm not sure being the year difference if they're the same or even remotely close, but worth a look. I dont understand why if you have a transfer case, and manual locking hubs, you need a vacuum actuated differential. Stupid.
  4. Feb 4, 2014 at 6:02 PM
    trailbikerider
    trailbikerider Well-Known Member
    Kalamazoo, MI
    Same thing happened to my '97 before I bought it, we just bypassed the solenoid and it works great now.
