4 wheel drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Nov 14, 2015.
  1. Nov 14, 2015 at 3:54 PM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    For the first time since new I had a little trouble getting into and out of 4 wheel drive. I got the blinking 4 wheel drive symbol but it took longer than usual to engage. It did engage and disengage after going back and forth a little but I was wondering if there's anything I should do so it goes in and out faster like before. Differential fluid for front and transfer case were done about 6 weeks ago. Tia
  2. Nov 14, 2015 at 4:07 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If the splines do not line up, or there is tension in the system, it is normal for the 4wd to not engage/disengage right away. This can also happen in a manual system. What you did was correct, just rock the truck back and forward or a little side to side and it will engage/disengage.
  3. Nov 14, 2015 at 6:02 PM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    do you regularly engage 4wd (monthly) to keep things moving and operating smoothly?
  4. Nov 14, 2015 at 8:05 PM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I always try to do the "once per month exercise the 4wd thing". I always do it on wet grass or dirt. I do the LSD, also. Don't forget to lubricate that driveline to. Just a few grease fittings to hit. You'll be glad you did.
  5. Nov 14, 2015 at 9:16 PM
    Beerline123
    Yes I regularly exercise the system that's why I was concerned by the slow response. I'm usually able to engage hi and low standing still.
