4 wheel not engaging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sabian, Sep 20, 2008.
  1. Sep 20, 2008 at 6:48 AM
    sabian
    sabian [OP] Active Member
    northern michigan
    SR5 tacoma
    Is any one experiencing this problem? I have an 08 taco, automatic 6cyl with just 2500 miles on it. When i try and shift into 4hi on the fly it will not engage. the icon on the dash flashes indicating it is not going in to 4 wheel. If i stop the truck it will engage. But repeated attempts fail when I try and engage while moving, and speed seems to have no effect.
    I am hoping this is just a fluke but will probably call the " ugh "dealer on this. I just know that with my old taco it would connect to 4 wheel in an instant with no problems. Any clues? Also I have kind of an idiot question but what is the A cab B cab and C cab. I see this when trying to purchase new floor mats but don't know what cab sizes correspond to the letters. Thanks for any input
  2. Sep 20, 2008 at 6:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sure why your 4hi isn engaugeing. But IIRC, "A cab" = Regular cab, "B cab" = ext. cab, "C cab" = quad cab. :)
  3. Sep 20, 2008 at 6:56 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My truck locked better at slower speeds when brand new. Now I have been working it out, she locks whenever and almost instantly when in park without even moving. I am afraid I am no help with the A,B,C cab thing.
  4. Sep 20, 2008 at 12:21 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    When Mine had 2500 miles on her and if I am in a steep incline and rough terrain and try to engage on the fly it just blinks at me until I stopped.....I tried it again the other day at slow speed and no incline and it engaged just fine....figured once I use it more it will probably get right but still I am going to ask next time by the stealer
  5. Sep 20, 2008 at 6:29 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I had a blinking light problem when my 4 wheel drive wouldn't engage. It turned out to be the 4 wheel drive actuator. Toyota fixed it under warranty. What stinks is when it goes, sol until replaced & hopefully not when you are wheelin. Oh my truck had 15k when it went.
  6. Sep 20, 2008 at 6:36 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i've dropped mine many times while driving at speeds...done it while stopped too...its weird that it wont lock in. only things i've seen about speed is to engage it under 65mph, i think
  7. Sep 20, 2008 at 6:48 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    What is the estimated cash value of that repair???
  8. Sep 20, 2008 at 10:03 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    when the light in mine flashes its actually engaged(i feel the torque steer and extra traction), though not fully i guess? to get the light to go solid just try to accelerate and then let off the throttle. if it doesnt work the first time then try a second and i almost guarantee it will go in all the way.
  9. Sep 20, 2008 at 10:31 PM
    RelentlessFab
    Eric
    Sparks, NV
    if this was directed to me: in 1st or 2nd gear, somewhere between 5-20mph is preferable for engaging 4hi, however i've engaged it doing 45mph on the highway when it started getting snowy/icy and it still goes right in:)
  10. Sep 20, 2008 at 10:52 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    You also might try slight turning of the steering wheel side to side while engaging.
  11. Sep 21, 2008 at 6:31 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    well the r.o. show actuator $339 & some F.I.P.G. The actual hours were not documented on it. I'm not sure if you can just take it off the trans. On my older toyotas w/ add you could sometimes tap it or clean it. Since it was under warranty and read other actuator failures in 06s, I think the system is temperamental compared to past Toyotas I have owned.
  12. Sep 21, 2008 at 9:28 AM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    Mine will engage on the fly but it will take a little while to do so, and yes, I do let off the gas a bit when shifting in to 4HI. It will come out of 4HI quickly, but is slow to go in. Or at least slower than the Ford that I drive for work.
  13. Sep 21, 2008 at 7:09 PM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    Thats an expensive repair. I effin hate electronics just for that reason. Just to take you off track, the newer Case skid steers and Bobcat's are so full of electronics they decide when not to work and thereby take a day or two off. Kind of like calling in sick. I read in a Bobcat forum, the newer machines are down 35% of the time. The older models like mine run almost all the time since they contain no complex electronics. Imagine buying a machine for 60K and its dead 35% of the time? :rolleyes:. How do you pay the bills if you are not working 35% of the time?
  14. Sep 22, 2008 at 4:39 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    I'm with you on electronics! 1/3 deadline rate? Thats missing a lot of work. Congrats on having the older model! Hopefully our trucks will not melt down so much but if they do the $880 deal from Troy on the Extended Warranty is worth it.
  15. Sep 22, 2008 at 5:24 AM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    I sort if wish my new '08 had a manual transfer and hubs like my '91. Then I would never have to worry about them going south.
