4 wheel problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HondaGM, Nov 30, 2009.
  1. Nov 30, 2009 at 11:10 AM
    HondaGM
    HondaGM [OP] CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i have a 09 dc 4x4 sport,never used the 4 wheel drive till yesterday,i stopped,put in neutral,turned switch to 4 wheel low,light came on dash,put back in gear and beeper goes off letting me know its not engaged in 4 wheel drive,went through the same proceeder again,and worked fine.i little while later i used four wheel drive again and it took 2 times to get it to engage........what i want to know is this normal or am i doing something wrong?:cool:
  2. Nov 30, 2009 at 11:39 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    What does 4HI do?
  3. Nov 30, 2009 at 11:40 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Totally normal. If i doesn't work, roll forward and try again.
  4. Nov 30, 2009 at 11:41 AM
    mikey05
    mikey05 Member
    05 DC Shortbed
    Too many to list
    There are numerous posts on this issue. After you use it a few times it will engage easier. Has to be used a bit for the actuator to move more freely.
  5. Nov 30, 2009 at 11:41 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    didnt try 4 high,went straight into 4 low,it goes in 4 low it just takes two or three trys to get it to engage.
  6. Nov 30, 2009 at 11:43 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    According to the owners manual your spozed to drive it in 4h for 10 miles every month to keep all the parts lubed and moving.
  7. Nov 30, 2009 at 11:44 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    didnt know that,thanx for info:D
  8. Nov 30, 2009 at 1:33 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Go into 4H first, once engaged, switch to 4L.
  9. Nov 30, 2009 at 2:16 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Agree
    1. get 4hi engaged first, then stop, put in nuetral, select 4low. may have to roll alittle to engage.
    2. Do this monthly to keep everything working, and you will also become very fimiliar on how your truck responds.
  10. Dec 1, 2009 at 6:53 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
