4 WHL low
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TACOTRDPRO1, May 17, 2023.
  1. May 17, 2023 at 6:52 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Huh.. My experience is the exact opposite. Nice smooth shifts if I let it roll a little. Need some coordinated footwork if on an incline, but it can still be done for sure.
    And as you stated in your follow-up post, the manual allows for anything under 2mph / 3kmh auto or manual
  2. May 17, 2023 at 6:53 AM
    TACOTRDPRO1
    TACOTRDPRO1 [OP] TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    :fingerscrossed:
  3. May 17, 2023 at 6:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well only manual trans, not auto. It states auto should be completely stopped. Maybe that's why my friend grenaded his case, or maybe it was just a freak occurrence, who knows.
    cryptolime likes this.
  4. May 17, 2023 at 7:08 AM
    SR-71A
    Zack
    Southern Maine
    hmm interesting. Guess I never read it that closely. I can tell you the buzzer is still set to 2mph in the autos though :notsure:
    EatSleepTacos[QUOTED] likes this.
  5. May 17, 2023 at 9:15 AM
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    I've always had best results at a complete stop, shifter in 1st, clutch pedal fully depressed. Blinks for a second or two, clicks, then ready to roll.
  6. May 17, 2023 at 10:19 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It will not go unless the clutch switch is pressed in. That requires holding the clutch all the way down for it to initiate. This is for 4LO only, 4HI doesn’t care about the clutch.
  7. May 17, 2023 at 11:15 AM
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    Same. Being in neutral either takes forever or never engages for me. 1st gear it'll engage within a couple seconds.
  8. May 17, 2023 at 11:37 AM
    TACOTRDPRO1
    ROCHESTER NY
    VERY INTERESTING, I WILL TRY THIS AS WELL. THANK YOU !!!
  9. May 18, 2023 at 3:49 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    This is correct.
    I thought mine engaged with the clutch out. Nope.
    I switch while in neutral, but the 4Lo doesn't actually engage (light on, beeping off) until I depress the clutch ...to shift into gear.
    BLtheP[QUOTED] likes this.
  10. May 22, 2023 at 4:44 AM
    TACOTRDPRO1
    ROCHESTER NY
    Here is a follow up on the above problem, I checked into every ones suggestions. EVERY ONES, including the manual.
    sad to report, still a big pain in my a...... I was trying this out this past weekend, for no reason at all after playing with this for 10 minutes I was letting it idle, clutch in and bang. I felt it click in ?? REALLY !! SO I did what I needed to do great no problem. NOW FOR THE FUN PART, trying to get it out of 4 low, that was worse then getting it into 4 low. THIS IS A JOKE. I cant be the only one with this problem. Truck has 2200 MILES,, THOUGHTS ???? YES I know warranty. I hate the [dealer] stealer-ships..
  11. May 22, 2023 at 5:45 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Clearly something is not right here brother! My advice is to quit fucking around and take the truck to your dealership for diagnosis. If something is wrong, your warranty will cover it. If nothing is wrong (and they prove it to you), worse case is you pay their diagnosis fee and drive off with your tail between your legs.
  12. May 22, 2023 at 6:45 AM
    TACOTRDPRO1
    ROCHESTER NY
    YOUR FUNNY GUY. LOL
  13. May 22, 2023 at 6:48 AM
    TACOTRDPRO1
    ROCHESTER NY
    I agree with with the 2 pedals my self..:bananadance: I will ck into this & let u know,, thanks
