4 year old battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrcheap, Feb 6, 2021.
  1. Feb 6, 2021 at 2:44 PM
    mrcheap
    mrcheap [OP] Well-Known Member
    Measuring 12v with the car off and 14v on. Should I plan for a new battery soon?
  2. Feb 6, 2021 at 2:49 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    dont understand battery anxiety/paranoia
    short suburban jaunts
    commuter bump & grind
    not the best yet a direct result of life styles & environs
    not unusual the batt is in deficit
    still not yet ready for a new one..................subject to the SAME circumstances
    hfjeff and TRDSport10 like this.
  3. Feb 6, 2021 at 2:50 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    Thats not how you test a battery. That sounds ok voltage though
    Key-Rei likes this.
  4. Feb 6, 2021 at 2:54 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    4 years old probably. A decimal point to the 12 volts might help but 4 years is about right for a flooded cell battery
  5. Feb 6, 2021 at 2:56 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Well at least your alternator is in good shape. The cranking amps of your battery are the real thing in question, and with cold weather that is what is crucial. You can go to Autozone or any other parts store and they'll typically test your battery for free and determine if it's almost time for replacement or not.
  6. Feb 6, 2021 at 3:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    14 volts running means your alternator is working. Turn on a few electrical loads like blower fan and hi beams, see if it stays up around 14 volts, it should
    For the battery itself, try this. Disable the fuel pump (pull a EFI fuse) and crank the engine over for a good 5-6 seconds while watching the meter. If the voltage drops below 10.0 the battery is weak.
    An even more backyard trick is to simply leave the headlights on for 10-15 minutes and see if the engine will still start. A strong battery should be able to run headlights for at least 15-20 mins and still start the car.
    *actual length of times above are just a rough example, if you want a more accurate method of testing buy a battery tester :p
    tinker_troy and TRDSport10 like this.
  7. Feb 6, 2021 at 3:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It would be better to know the number AFTER the decimal point.
    Ideally, you want 12.6+
    However, you test a better under load.
    So the voltage in a battery not under load, really doesn’t help in this situation.
    Muddinfun likes this.
  8. Feb 6, 2021 at 3:31 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I never could plan on replacing a battery because there is no way to ever know how long a batt. will last. Many get replaced before the free replacement warranty is out & many last waaaaay longer than the complete pro rated warranty period. I've never replaced any battery till it shows some sign of a problem, but that's just me.
    devkurf and Accipiter13 like this.
  9. Feb 6, 2021 at 4:21 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    YUP. On a well maintained vehicle the battery will give you plenty of notice. Much like water pumps and alternators.
  10. Feb 6, 2021 at 4:25 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Not unless it gives you trouble. If you are worried get a NOCO battery jumpstarter.
    TTT and TRDSport10 like this.
  11. Feb 6, 2021 at 4:31 PM
    wmgeorge
    wmgeorge Well-Known Member
    Fully charged battery 12.6 volts, running 13 volts or better. Battery's should last 5 years over that who knows. Toyota seems to have good battery's Johnson Controls makes for them.
    TRDSport10 likes this.
  12. Feb 6, 2021 at 4:49 PM
    Waasheem
    Waasheem
    2007 xrunner
    Some of the better multimeters have a peak high and low feature. Connect it to your battery, set the meter for peak low dc volts, start the engine. It'll record the lowest point the voltage dipped to. Trying to do the same with a digital multimeter without the peak feature isn't possible. It'll flash a lower number, but it's not the same, I've tried.
    Here's the part that's subject to interpretation. Starter voltage drop test, 10.5 or below is what used to be taught but I think that was because alternators were set to charge to 14.7. Now I'm seeing brand new vehicles charging to 14.2, starter voltage drop testing showing 10.2 on a new vehicle. A recent training video I watched said 9.6 or below is a fail, this seems very low to me, so low that a battery with that result would noticeably crank slow, as in battery is weak.
    I have a battery load tester that will fail every battery I put it on other than one that's brand new. So I only use it, along with a amp clamp, to put a load on the battery, with the engine running, to test the alternator charging output. If the belt is loose, it's best to adjust before this test or the belt will squeel like crazy. Really, I rarely do this test because the load tester is so dang big.
    Battery terminals and posts get dirty, acid covered, oxidized, corroded over time. A cleaning with baking soda and a battery brush will do wonders. If your terminals need soaking to get clean, the best thing I ever used is soda as in coke, diet coke, pepsi, whatever. Battery terminal protector, everyone has their opinion, everyone is right. Nothing, huge gobs of axle grease, felt discs, spray on stuff, pick your poison.
    Parts stores are in business to make money selling parts. If you show up and ask for a free battery test, they're going to try to sell you a battery. That is unless a good friend of yours works there and does the test, then you should get the truth.
    Another good rule of thumb, if it's more than 5 years old, plan to replace it no matter what testing result you get. If it tests good, you can shop around for a good deal, but don't wait too long, it'll leave you stranded unexpectedly. When I bought my Tacoma, the battery was 7 years old. I tested it, and it passed very good. It wasn't long before it started cranking weak, and I'd have to jump it if it sat for too long.
    Which battery to get, don't get us started. Everyone has their opinion, everyone is right.
  13. Feb 6, 2021 at 5:00 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If an aftermarket (assume 2009 Tacoma from profile) it depends on quality of battery and in what state as hot climates eat batteries faster.
    Peace of mind is a factor also. In FL I change mine every 4 years and its an AGM. I keep the previous one as backup on off road trips often solo.
    I also tow boat trailers and getting stuck on a busy ramp sucks. Up to you.
  14. Feb 6, 2021 at 7:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That isn't necessarily or always true, and why I always carry jumper cables. ( I need to get one of those jump packs ).
    I replaced mine last month. Started as always no issue at all, drove to work and shut it off. Nothing was left on. Came out 8 hours later and it wouldn't even light the headlights. Graveyard Dead. Got a jump start from a co-worker and drove it home. Turned off at home and attempted to restart immediately and nothing, not even a click.
    There was no warning.
  15. Feb 6, 2021 at 10:32 PM
    TnShooter
    Deogee
    STOCK
    Be sure to read the reviews on those jump boxes.
    I’ve had 2 of the new lithium small jump packs.
    I never had any luck with them on anything other than my lawn mower.
    I finally went back to the old style big jump box.
    It’s big and heavy but it works.
    I’m not saying the new lithium packs don’t work.
    As a lot of guys seem to like them.
    I’m betting part of my problem was the amount of money I spent on them.
    (Yeah, the old say was true. I got what I paid for)
    Jimmyh[QUOTED] likes this.
  16. Feb 7, 2021 at 3:07 AM
    devkurf
    devkurf Member at Large
    midwest
    This. A battery usually will give you signs its about done before it leaves you stranded. Turns over slow, lights dim down when cranking, windows roll up slow when not running. I look at replacement when the signs start popping up, not solely based on a predetermined time frame.
  17. Feb 7, 2021 at 3:45 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    For peace of mind, I usually just replace a battery every four years. I’ve had batteries give a subtle warning that they were going bad and I’ve also had them totally crash with no warning. Always seems to conk out at the worst time.
    Markcal and Sprig like this.
  18. Feb 7, 2021 at 5:08 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Good point blockhead, you could replace them ever 2 yrs. a feel even more peace of mind. Yes, todays improved batts. don't give near as much, & sometimes no warning. But I'd sure be disappointed if I replaced a batt. after 4 yrs then gave it to a friend who drove it another 4 yrs. So I'm like Jimmyh, I'll replace it when it needs replacing, but everyone has got to do what makes them feel peace of mind. I guess no wrong answers. Good luck to all.
    Jimmyh likes this.
  19. Feb 7, 2021 at 5:34 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks for the tip. The last one I had was huge but it did the job for years, but gave up the ghost after about the 11 year point.
  20. Feb 7, 2021 at 5:46 AM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I go by how well it turns over the engine after sitting all night. I don't take voltage measurements or go solely by age. As soon as it starts to struggle on a regular basis, it is time. All it takes is a morning like today (-17 F here in the Frozen Tundra) to put that to the test.
