4000 rpms at 70mph?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kasemo223, Jul 15, 2017.
  1. Jul 16, 2017 at 3:53 AM
    Indy
    Indy Master of all I survey.
    You can go bigger on the tires but only if the truck will allow it.
  2. Jul 16, 2017 at 3:59 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Good eye. Didn't catch that.
    If you're keeping the truck for a long while, the dip in gas mileage with end up being more expensive.
    mosquitoTaco[QUOTED] likes this.
  3. Jul 16, 2017 at 4:07 AM
    Indy
    Something is not right. Looking at marlin crawler and using gear calculators, the steepest gears they have are 5.71. Combined with a 32 inch tire in 5th gear at 70mph you're turning only 3500rpm. I guess it's possible to go with deeper gears but 5.71 would be fairly rare to find to start with. Even the manufactures recommends against them because they're weak.
    With that ratio you'll be turning 4200 in 4th.
    With gearing low enough to make the listed problem happen you're not really driving around much. You should have 3 useless gears and be able to launch from a dead stop in 3rd/4th gear. Starting in first you would do 3 gear changes before you crossed an intersection. And you would need 44" tires to get down to 25ish rpm in 5th. There would be no question if your truck was capable of 44s. It would be pretty obvious.
    You're not driving around in low range are you?
    Anyway with the assumption you have mystery gearing the only way to check is to actually check. Rear end on jackstands, crawl under and have someone turn the wheels 1 revolution. Mark the driveshaft and count how many time it turns.
    If you have an open diff you can put 1 wheel up, multiply the dshaft rotations by 2. Or turn the wheel 2 revs. Either way you'll have a rough idea of the gearing.Tobe more exact pull the diff and count the teeth.
  4. Jul 16, 2017 at 5:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Based on the information that is bouncing around here, I think a reconsideration of the above post is in order............
  5. Jul 16, 2017 at 9:14 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Anyone concider the Tach could be off before jumping to such big conclusions as needing a regear?
    TacomaJunkie8691 likes this.
  6. Jul 16, 2017 at 9:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    Post 11
    vern650[QUOTED] likes this.
  7. Jul 16, 2017 at 9:46 AM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    That is the factory size and factory tire for that truck. Piece of S. tire. I sell tires and just so you guys know that tire is not made in a p265/70R18 its only made in the 2 sizes below. Only way to know what gearing you have is count the pinion gear teeth and then you will know what gears are is in it. If i was to guess that truck has 4:88 or 4:56 but im sure its 4:88. Use a gps to verify your odometer a 37" tire spins at 64.63 mph on 4:88 gears. It,s perfect for turning big tires or low speed rock crawling. It will kill your gas mileage on the freeway.
    P275/65R18 114 T
    P275/70R18 116 T
  8. Jul 16, 2017 at 9:57 AM
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    that tire is exactly 30.6" not 32.5" your way off sorry. GPS will tell instantly what the problem is. check this link for rpm change with my tire size.
    https://www.tacomaworld.com/tirecalc?tires=265-70r16-37-12.5r20
  9. Jul 16, 2017 at 10:01 AM
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    If you have 4:88 and 265\70r16 your gps should show you at like 51-55 mph while indicating 65mph. So 20-21% off
  10. Jul 16, 2017 at 10:17 AM
    Madjik_Man
    Colorado Front Range
    I essentially have the same truck.
    At 70 mph in 5th gear I'm around approx 2700 rpms
    Something is not right with your truck. I suspect a previous owner regeared.
  11. Jul 16, 2017 at 10:53 AM
    NM Lance
    NM Lance Well-Known Member
    Get in it and try starting it from a dead stop in 3rd gear on a level surface. If you can do it without the engine knocking or lugging badly then it is probably gears.
    Otherwise I am betting on Clearwater Bill's suggestion.
    FirstTimeFirstGen likes this.
  12. Jul 16, 2017 at 10:57 AM
    kasemo223
    kasemo223 [OP] Member
    Wow thanks everyone for responses I'm overwhelmed lol, okay so when I drive into work I'll take the GPS and see my mph compared to that and then ask a buddy to use the scanner tool and see if my rpms are off from the tach and I'll report back me edit-- also I will try the third gear start
  13. Jul 16, 2017 at 11:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not exactly the 'only' way. Same idea here, but a lot less effort to accomplish.
    http://www.how-to-build-hotrods.com/gear-ratio.html
  14. Jul 16, 2017 at 11:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    As long as its not just a code reader scanner. That won't help.
    It needs to be a real time scan. And not just reading RPM at idle, but at speed. A tach can be accurate on the low end and bonkers on the high end, so you need to see what it's doing all across the range.
  15. Jul 16, 2017 at 12:18 PM
    #35
    Madjik_Man
    Does it sound like it's at 4000 rpms? Or lower rpms?
    NM Lance and TacomaJunkie8691 like this.
  16. Jul 16, 2017 at 12:54 PM
    #36
    kasemo223
    Update! For you bill, I was able to take off from 3rd gear without lugging it at all , and for majik_man, yeh if I had to guess it would seem around 4000 rpms that's why I don't go past 70mph as I feel if I get to 75 I want to shift into gears I don't have haha , and the GPS seemed to be close to mph gauge (clocking in for work now will msg when I can )
    mosquitoTaco likes this.
  17. Jul 16, 2017 at 3:26 PM
    #37
    DustStorm4x4
    U S A
    04 Jeep LJ
    Right we established this already. I thought it said 18. Not 16. But thanks again.
  18. Jul 16, 2017 at 3:46 PM
    #38
    Indy
    30 inch tires, 5th gear 5.71 gears, 3807rpm. Again, 5.71 really rare. Jack up the wheel and count the revs. No more mystery after 5 minutes work.
    kasemo223[OP], NM Lance and TACOVRD like this.
  19. Jul 16, 2017 at 10:08 PM
    #39
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I was going to suggest clutch slippage but if you can take off fine in 3rd gear that's out the window :p
  20. Jul 16, 2017 at 11:02 PM
    #40
    kasemo223
    Going to jack rear end up tommorow and find out for you all, thanks everyone I'll report back tommorow
