4000 rpms at 70mph?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kasemo223, Jul 15, 2017.
  1. Jul 17, 2017 at 6:42 AM
    #41
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    :popcorn::popcorn: Waiting for updates
  2. Jul 17, 2017 at 11:24 AM
    #42
    kasemo223
    kasemo223 [OP] Member
    Update , 2 and a half turns per one wheel rotation give or take.
  3. Jul 17, 2017 at 1:29 PM
    #43
    Clearwater Bill
    Billy
    Largo Florida
  4. Jul 17, 2017 at 1:40 PM
    #44
    kasemo223
    Well it was closer to 2 3/4 for my one tire spin, should I have done 2 as it says for non posi? I have the factory e locker and it was not on, I can try again but will have to wait tommorow as I used a friend's jack, thanks for quick response tho - EDIT- does 2 3/4 not sound right at all? If I did two rotations it would be 5 1/2
  5. Jul 17, 2017 at 2:04 PM
    #45
    kasemo223
    I'm not in low gear , but my 4x4 does not work at all , is it possible it could be stuck in low gear even tho the shifter is in high?
  6. Jul 17, 2017 at 2:48 PM
    #46
    Clearwater Bill
    Billy
    Largo Florida
    Yes, an elocker is not a posi.
    While this process of course is a bit of a guesstimate (as opposed to opening things up and counting teeth), it's close enough for what you are trying to accomplish.
    The resulting number you have is pretty close to what Indy's calculations show below, at least enough to pretty well prove you've been wildly regeared.
    Add that to the fact that you've got a non working front diff (or at least the controls are out?) hopefully you got a screaming bargain on this thing.
    I can't even imagine what kind of MPG you're getting on the road. Or should I say aren't getting.
    kasemo223[QUOTED][OP] likes this.
  7. Jul 17, 2017 at 2:58 PM
    #47
    kasemo223
    Thanks a bunch yeh I got it for a decent price I felt for being in north bay , so getting bigger tires would not do much for me eh, best bet would be to just regear?
  8. Jul 17, 2017 at 3:09 PM
    #48
    Clearwater Bill
    Billy
    Largo Florida
    You can play with the tire calculator and see what taller tires would do for you. Just remember they have to fit the truck. If you get all wound up in suspension changes to support it, you'll wind up spending more than the regear.
    What you need to determine at this point is if the front was also regeared. It should have been so things worked together off road.
    That said, it's possible you could find a local that would want your gearset and swap with you. Their gears and them funding the labor could make a good deal for you, assuming you want to back off to stock gearing. Just a thought.
  9. Jul 17, 2017 at 3:32 PM
    #49
    kasemo223
    Any perks to having this gearing? My main goal when posting was just to lower my rpms for highway driving
  10. Jul 17, 2017 at 3:37 PM
    #50
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Helps you tow really heavy shit, and makes your wallet lighter due to gas mileage
  11. Jul 17, 2017 at 3:42 PM
    #51
    Clearwater Bill
    Billy
    Largo Florida
    It's drag racing gearing w/o the grunt to go with it. IE you make the engine work hard quicker.
    It's great for crawling over and through stuff, as you don't have to have high revs to move the vehicle.
    It stinks on the highway.
    It's really an off road item. Especially at the whacked out ratio you seem to have.
  12. Jul 17, 2017 at 3:48 PM
    #52
    kasemo223
    Ah well I don't do any towing, but yeh that would make sense the guy I purchased from has alot of custom rock crawler stuff , just wish I would have known when I got it (live n learn) at this point I'll most likely just put as big of tires as possible on it and just keep gearing the same , the only crawling I do is the the cow mountain rifle range lol, maybe I'll have to branch out.
  13. Jul 17, 2017 at 9:00 PM
    #53
    Indy
    Indy Master of all I survey.
    5.71s are not good for towing. They are weak gears, physically, so heavy stress like towing will likely damage the teeth. But super low gears make off roading much nicer. A better approach though is to spread the gearing change out. A bit steeper in the diffs to make up for tire size and then lower in the t case so you have the grunt when you need it and still have normal rpm when you dont. But just doing the diffs and dealing with it is the norm. Cheaper and easier, so more common.
    Id guess would be the front diff wasn't regeared. It wouldn't be the first time someone geared the back and pulled the front dshaft until they could gear the front.
    31/32 is likely the tallest tire you'll be able to fit with factory suspension. Odds are you can find someone to swap 3rd with, get closer to reasonable.
