4000 # trailer pulling question(s)...
Discussion in 'Towing' started by flashsplat, May 22, 2012.
  1. May 22, 2012 at 7:26 AM
    flashsplat
    flashsplat [OP] Well-Known Member
    Augusta, GA
    2012 SM 4X4 DC TRD Off Road
    I put gas in it...
    So, I started my own business and I now have an enclosed trailer that's pushing 4000#'s with all of my gear in it. I pretty much just leave the trailer attached 24/7 and only take it off when I hook up my boat.
    My rear is sagging pretty good with the trailer on and my question is, is that okay? To just leave my truck like that all the time? Am I damaging my leafs in the rear or anything? I have the stock 2012 TRD Off-Road suspension.
    My other question would be: Can anyone suggest a good brake controller for my Taco?
    Thanks,
    Flashy
  2. May 22, 2012 at 7:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you tow that much, I'd look into a set of air bags and possibly a weight distributing hitch setup.
  3. May 22, 2012 at 7:43 AM
    flashsplat
    Augusta, GA
    I put gas in it...
    HRmmm.. Weight Distribution.. I'm not entirely sure what that's for, but I can say that I've passed and been passed by Semi's and the trailer stays right behind me. Doesn't feel unsafe... Might be the better way to go though..
    Craaap.. More $$$
    I'm going to take a picture of how it's sitting now maybe that'll help some. I also see now that there is a "towing" section. This may have been a better fit there...
  4. May 22, 2012 at 8:00 AM
    Pugga
    Massachusetts
    F-150 Mod
    A weight distribution hitch uses torsion bars to essentially lift up on the rear of the truck which, in turn pushes down on the front end. For trailers with a heavy tongue weight, this helps fight that unweighted front end feeling and takes some of the weight off the rear end and makes the front end take some of it on.
    The Tacoma's suspension really does suck from the factory so it's most likely not that you're overweight, is just that the leaf springs are soft. Depending on your situation, air bags or a WDH setup would make towing a bit easier and keep the back end from sagging as much.
    For a flat utility type trailer, I'd go with air bags. For a heavier travel trailer, a WDH might be a better option.
  5. May 22, 2012 at 9:28 AM
    a89aries
    a89aries Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
    I don't know how you move that without electric brakes right now! I just bought the cheapest POD off a friend and wired it in with the adapter plug, works great!
  6. May 22, 2012 at 12:34 PM
    Conti
    Conti Member
    Pacific North West
    2006 TRD Sport
    - Taunu cover - Bull Bar - Nerf Bars - Tinted Front Windows - Bed Cubby Lights - Larger Tires - 265/70/17 Hankook Dynapro ATM - Fog Light Mod. - Under Hood Light - Tailgate Pop and Lock - Hood actuators - Ordered from RedLine Tuning - Roof Rack - Tacoma Roof Rack from Toyota Parts Zone - Ultra-Guage - 4 wheel drive switch illuminated - Custom board and leds - Mag Lite Mount - Mini Flash Lite Mount - Tview T90DVFD 9 Overhead DVD player - GPS System - Tom Tom 340 - Brake Controller : Tekonsha Prodigy Trailer Camper Brake Control - EGR In-Channel Window Visors - Drop in K&N Filter - Plasti Dipped Badges - Wired Aux jack into OEM Radio - Shorty antenna - Oem bed mat. - Weather Tech mats black. - Quick Fist Shovel and Ax Mount - Extra D Rings in front of Bed - LED Bed Cubby Lights - Reverse Lights - Hardwired with switch in cab. - Ride Rite Air Bags - On Board Air (OBA) : MV-50 compressor, Viair Tank (2.5 gal 200 psi), in cab dual needle gauge, manual paddle valve for air bag
    I have a 19' Travel Trailer around 4000 lbs fully loaded... I use a WDH and a Tekonsha Prodigy P2 Brake controller. I just installed Air Bags to help level the back when the bed is loaded down as well. Haven't pulled the trailer since the air bag install but I like the airbag solution better. It works no matter what I pulling or hauling in the bed. I have the stock leafs without the TSB.
  7. May 22, 2012 at 1:14 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Since you are a off-road model did you get the leaf TSB so at least your have a 4 pack of springs instead of 3.
    I would do that since it is free and your current leafs are likely done for. Then get a set of air bags to stop the new set from sagging right away.
    The weight dist hitch is nice. It is different than the sway control you are likely thinking of by mentioning the trailer not moving when passing semi's.
    How much of the weight in your trailer is up front in it.
    Have you ever checked each axle weight while hitched up and without the trailer?? Front truck, rear of truck and trailer??
    This will show you how the trailer impacts the truck.
  8. May 23, 2012 at 10:32 AM
    flashsplat
    Augusta, GA
    I put gas in it...
    Yeah, i think @ the very least I will get a brake controller.. ty
    I like the idea of airbags. More of a manual control vs. counting on the WDH..
    I have a 2012 Off Road, and only 3 leafs. Would there be a TSB for the 4th leaf even on a 2012?
    Thanks,
    Flashy
  9. May 23, 2012 at 7:17 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    I am not positive if the TSB applies to 2012 truck but it should since the 3 leaf is crap. Post up in the 2nd gen forum and I am sure someone will chime in. I know it covered 2011 but took awhile for toyota to update the TSB to include 2011 after they hit the showroom.
    I have towed 3500 with and without trailer brakes and it is a nice addition. Mine were surge brakes so no recommendation on the controller.
    The WD hitch setup is nice to have if you haul alot since it spreads the weight throughout the truck and makes it handle better and less sway.
    4K is not bad but really depends on what speeds you see and how long of a haul you are doing.
  10. May 23, 2012 at 7:20 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    reorganize your trailer
    i notice people put all the weight on the tongue instead of over the trailer axles. i haul cars all the time with my 05 tacoma and it barely sags at all because i keep the car centered on the trailer instead of all the way forward
    just my $0.02
    Douglas1953 likes this.
