400k club
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bigoldbeef, May 17, 2021.
  1. Oct 18, 2022 at 9:32 AM
    #81
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Holy shit that is a hard working truck. Good work, man.
    Junkhead likes this.
  2. Oct 18, 2022 at 10:49 AM
    #82
    bigoldbeef
    bigoldbeef [OP] Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    that’s what I’m thinking. I already put defoulers on cuz I was getting a consistent p0420 for a while. The combination of the two is a new development.
    hiPSI and Junkhead like this.
  3. Oct 18, 2022 at 11:28 AM
    #83
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'd be a little nervous about the p11ed. That code seems to point to burnt valves and head/valve rebuild or replacement.
    P11ED00 Cylinder #2 Air-Fuel Ratio Imbalance (Port) The difference in air fuel ratios between the cylinders exceeds the threshold (2 trip detection logic).
    • Port fuel injector assembly
    • Direct fuel injector assembly
    • Intake system
    • Gas leaks from exhaust system
    • Ignition system
    • Compression pressure
    • Air fuel ratio sensor (sensor 1)
    • ECM
    Comes on DTC stored SAE Code: P11ED
  4. Oct 18, 2022 at 11:34 AM
    #84
    McChillen
    McChillen USAF Veteran
    Denver
  5. Oct 18, 2022 at 5:32 PM
    #85
    Soonr1
    Soonr1 Well-Known Member
    2022 Army Green TRD Off Road
    This is incredible. On the high mileage thread most of the 3rd gens are the 2.7. It’s nice seeing the 3.5 on here. That trucks a pure workhorse.
  6. Oct 18, 2022 at 5:50 PM
    #86
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    @ksimms92
    Yeah, this is an old reply but worthy of an inquisitive reply. lol
    I say this because it took me 16+ years to get 200K miles on my 2003 Honda Pilot (purchased in HI in 2002).
    Pilot spent 3 years in Germany and Italy as well as Delaware in between...and did a cross-country trip from Dover, DE to Alamogordo, NM.
    I was on my third set of tires and bought new rotors during that last brake job. Timing belt done at 90K and replaced the transmission at 190K miles.
    Then in Oct 2018, some lady decided to be in the suicide lane and ruined my day.
    Longevity is a mainstay with these vehicles from Japan.
  7. Oct 18, 2022 at 5:52 PM
    #87
    bigoldbeef
    Hopefully its not the valves. It runs fine, doesn't idle rough or throw any misfire codes like some of the others with a similar code. When it does throw the code its in the morning before or right after the truck gets up to operating temp. I'm gonna replace the spark plugs again this weekend and check compression in all of the cylinders while they're out.
    Junkhead, Canadian Caber and hiPSI like this.
  8. Oct 18, 2022 at 6:02 PM
    #88
    saint277
    saint277 Vigilo Confido
    How many miles on those plugs?
  9. Oct 18, 2022 at 6:28 PM
    #89
    RX1cobra
    19 OR
    Good plan but you may want to do a leakdown instead of compression test.
  10. Oct 18, 2022 at 7:11 PM
    #90
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    In 2018 I put a 1000 miles a week on my Tacoma. It is possible
  11. Oct 18, 2022 at 7:16 PM
    #91
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I'm not saying it isn't possible.
    My testimonial was unintended but profoundly rewarding.
    hiPSI[QUOTED] likes this.
  12. Oct 18, 2022 at 7:27 PM
    #92
    Tacojumper
    Tacojumper Well-Known Member
    2021 trd off road
    tacoma's truly last forever
  13. Oct 19, 2022 at 3:42 AM
    #93
    bigoldbeef
    142k on this set.
  14. Oct 19, 2022 at 3:55 AM
    #94
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I'm over 173k mi right behind you and truck is healthy and strong
    Edit fyi mines a 17. Little story , my truck sat at lot for almost a yr with 4 miles on it . I found my truck in 2018. So as it goes mines a 2017 picked it up brand new in 2018. Lol crazy right? 5k mi oil changes , routine maintenance, premium fuel , and plain old take care of my truck.
  15. Oct 19, 2022 at 7:19 AM
    #95
    PolakTaco
    PolakTaco Well-Known Member
    FL
    2022 Tacoma SR5 4x4 V6
    When we were in the office 5 days per week, I had a 100 mile roundtrip to work, which came out to be 500 miles per week or 2000 miles per month.
    We are hybrid for now but returning to 5 days per week in January. Commute is going to suck big time, but you get a job where one is available and sometimes for the decent jobs you have to drive further. I have old beater car that I'm planning to use and split the miles with the truck.
  16. Oct 19, 2022 at 7:37 AM
    #96
    kucelkj
    kucelkj Member
    Ken
    Ambridge, PA
    2011 SR5
    ARE cap, bed rug matt, Weather Tech floor mats, Toyota skid plate up front, kick butt flashlight and a 38 snub nose.
    Wow, you really tow some heavy stuff. That's encouraging. I have a 6x14 enclosed and 7x16 flat trailers. Both tandem axle. And sometimes I think I'm towing heavy.
  17. Nov 21, 2022 at 7:28 PM
    #97
    bigoldbeef
    Gonna roll 300k this week :burnrubber:
  18. Nov 21, 2022 at 7:48 PM
    #98
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Good work, Beef!!! Keep us posted! :burnrubber:
  19. Nov 21, 2022 at 7:53 PM
    #99
    FifthGent
    FifthGent Well-Known Member
    2022 OR DCSB
  20. Nov 22, 2022 at 3:43 AM
    #100
    Soonr1
    You’ve gotta have the highest mileage 3rd gen and you give me hope for mine lol.
