400watts plug-freezer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by snowmanquebec, May 17, 2010.
  1. May 17, 2010 at 12:13 PM
    snowmanquebec
    snowmanquebec [OP] Member
    Clova & Montreal QC,Canada
    TRD 2010
    mickey thompson tires
    i would like to know if i can plug a small freezer in the back of the tacoma into the 400watts electric outlet.
    the freezer is rated:115 volt,5 amp,60 hz
    i really need to run the freezer in the back of the pick up for 8 hours drive.
  2. May 17, 2010 at 12:15 PM
    Crusher 2
    Crusher 2 Well-Known Member
    N. Virginia
    06 Dbl cab,mostly stock
    probalbly not. 115v x 5 amps is 575 running watts. In rush current when compressor starts is much higher (estimated 125%).
    Pack freezer with dry ice... it will last for days.
    Crusher
  3. May 17, 2010 at 12:18 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    Crusher gave you the straight facts. The Dry Ice will do the trick
  4. May 17, 2010 at 12:30 PM
    snowmanquebec
    TRD 2010
    So this is how we calculate the power in watts
    115volt x 5 amps =575 watts
    or
    115 volt x 4 amps =460 watts
    thank you
  5. May 17, 2010 at 12:34 PM
    Crusher 2
    N. Virginia
    We can buy dry ice in local Safeway stores around here.. reasonably priced. Read the precautions with Dry Ice. Very dangerous to touch and will freezer burn your freezer contents with direct touch. Oh and don't lock the freezer door! Dry Ice sublimates..(turns directly from solid to gas) and needs room to expand/escape the freezer compartment. Or BOOM!
    Crusher
  6. May 17, 2010 at 12:46 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    plus when you put it in drive I'm pretty sure the wattage drops unless modified.
  7. May 17, 2010 at 2:04 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    isnt that the same calculation? except where are you getting the 4amps?
    get an ultracool icechest. if you prefreeze everthing, and stuff it full..you wont even need dry ice..8 hours aint nothing,with the right ice chest.
